CISCO 3745 Problem-Please help ASAP.
nickolaskoiser
I have a cisco 3745 router that supports the whole WAN,it has four E1 cards and a number of ethernet modules,It has been working OK till this morning when it failed to boot this is the error that i get:
Cisco IOS Software, 3700 Software (C3745-ENTSERVICESK9-M), Version 12.4(19), REL
EASE SOFTWARE (fc1)
Compiled Sat 01-Mar-08 00:56 by prod_rel_team
%ERR-1-GT64120 (PCI-1): Fatal error, Parity error on master read
GT=0x24000000, cause=0x00100000, mask=0x00D01D00, r
bus_err_high=0x00000000, bus_err_low=0x00000000, addr_decode_err=0x00000470
r0 = FFFFFFFF r1 = FFFFFFFF r2 = 0 r3 = 64250000 r4 = 0
r5 = A110121 r6 = FFFFFFFF r7 = BFA00000 r8 = 0 r9 = 0
r10 = 0 r11 = 1 r12 = 0 r13 = 400A80 r14 = 0
r15 = 400A80 r16 = 0 r17 = C100 r18 = 0 r19 = 0
r20 = 0 r21 = 0 r22 = 0 r23 = A80 r24 = 0
r25 = 400000 r26 = 0 r27 = 8 r28 = 0 r29 = A00
r30 = 0 r31 = 8 r32 = FFFFFFFF r33 = FFFFFFFF r34 = FFFFFFFF
r35 = FFFFFFFF r36 = FFFFFFFF r37 = FFFFFFFF r38 = FFFFFFFF r39 = FFFFFFFF
r40 = FFFFFFFF r41 = FFFFFFFF r42 = FFFFFFFF r43 = FFFFFFFF r44 = FFFFFFFF
r45 = FFFFFFFF r46 = FFFFFFFF r47 = FFFFFFFF r48 = 0 r49 = A
r50 = 0 r51 = 0 r52 = 0 r53 = 3041A801 r54 = 0
r55 = 100000 r56 = FFFFFFFF r57 = FFFFFFFF r58 = 0 r59 = 64867770
r60 = FFFFFFFF r61 = FFFFFFFF r62 = 0 r63 = 6027F688
sreg = 3401C103 mdlo_hi = 0 mdlo = 0
mdhi_hi = 0 mdhi = 0 badvaddr_hi = FFFFFFFF
badvaddr = FFFFFFFF cause = FFFFFFFF epc_hi = 0
epc = 6027F680 err_epc_hi = FFFFFFFF err_epc = FFFFFFFF
%ERR-1-FATAL: Fatal error interrupt, reloading
err_stat=0x0
=== Flushing messages (00:00:35 UTC Fri Mar 1 2002) ===
Queued messages:
00:00:35 UTC Fri Mar 1 2002: Interrupt exception, CPU signal 22, PC = 0x0
Possible software fault.
Please help,i have no other router that can work in its absence.
7 Replies 7
ghanshyam.saini
Did You try upgrading image?
guruprasadr
Level 7
Level 7
HI Nickolas, [Pls Rate if HELPS]
Please share the tech-support or show stacks and show version command output
to have the Stack Decoder analyze any crashes that might have occurred. Otherwise, replace the appropriate component after a second failure.
Explanation: This error message indicates a Hardware problem in the device.
Recommended Action: To troubleshoot try this:
1. Reload the device with no modules installed and check if the message appears.
2. Reload the device with each successive module and check to see if a certain module or mis-seated module is causing this issue.
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
smothuku
Level 7
Level 7
Hi ,
First remove all the modules from slots and try to boot the router.
If you face same problem after removing all the modules , then try to upgrade the IOS.
Satish
Thanks man,
This worked,the router has four e1 cards,i tried each card step by step and finally i was able to boot well with the card in slot3 out,so does this mean that this E1 card is having some fault,Please help because i have just bought this card recently.
Once again thanks for your advice.
This is what I found on cisco.com -
The error message relates to the bus error. The bus error can happen either due to the hardware modules problem or due to the router chassis problem.
Complete these steps in order to isolate the issue:
Power down the router.
Remove all network modules and power back on the router.
Power up the router.
If the router goes back into a boot loop with the error message, the chassis might be defective.
If the router boots normally, power down the router, install one network module, and power back up.
Continue to install one network module at a time because the hardware causes the issue. This should be done until the network module or chassis slot is isolated.
Replace the part determined to be defective.
If the router does not go back into the boot loop mode after you reinstall all modules, the issue might be a mis-seated network module.
- http://www.cisco.com/en/US/products/hw/routers/ps282/products_tech_note09186a008075fd05.shtml#bh11
-> Sushil
Sushi:
Good find. Nice research.
Gave you 5 points, buddy...
Victor
Hey thanks for the appreciation Victor.
