%IP-4-DUPADDR error message
trinawong
Dear All,
There are error messages flood with '%IP-4-DUPADDR: Duplicate address 10.10.10.3 on FastEthernet0/0, sourced by 0009.6b62.1676'. The Duplicate ip address 10.10.10.3 is the virtual ip address of RouterA, could you please advise why the error message show up and why the virtual ip address has two different mac address on different router. thanks a lot!
Apr 29 04:11:33: %IP-4-DUPADDR: Duplicate address 10.10.10.3 on FastEthernet0/0, sourced by 0009.6b62.1676
Apr 29 04:12:03: %IP-4-DUPADDR: Duplicate address 10.10.10.3 on FastEthernet0/0, sourced by 0009.6b62.1676
Apr 29 04:12:33: %IP-4-DUPADDR: Duplicate address 10.10.10.3 on FastEthernet0/0, sourced by 0009.6b62.1676
Apr 29 04:13:04: %IP-4-DUPADDR: Duplicate address 10.10.10.3 on FastEthernet0/0, sourced by 0009.6b62.1676
Apr 29 04:26:14: %IP-4-DUPADDR: Duplicate address 10.10.10.3 on FastEthernet0/0, sourced by 0009.6b62.1676
Apr 29 04:26:44: %IP-4-DUPADDR: Duplicate address 10.10.10.3 on FastEthernet0/0, sourced by 0009.6b62.1676
Apr 29 04:27:15: %IP-4-DUPADDR: Duplicate address 10.10.10.3 on FastEthernet0/0, sourced by 0009.6b62.1676
Apr 29 04:27:45: %IP-4-DUPADDR: Duplicate address 10.10.10.3 on FastEthernet0/0, sourced by 0009.6b62.1676
RouterA#
RouterA#sh clo
04:40:24.651 GMT Tue Apr 29 2008
RouterA#sh arp | i 0009.6b62.1676
Internet 10.10.10.201 0 0009.6b62.1676 ARPA FastEthernet0/0
Internet 10.10.10.150 0 0009.6b62.1676 ARPA FastEthernet0/0
Internet 10.10.10.183 0 0009.6b62.1676 ARPA FastEthernet0/0
Internet 10.10.10.190 0 0009.6b62.1676 ARPA FastEthernet0/0
Internet 10.10.10.168 0 0009.6b62.1676 ARPA FastEthernet0/0
Internet 10.10.10.35 1 0009.6b62.1676 ARPA FastEthernet0/0
RouterA#sh run int fa0/0
Building configuration...
Current configuration : 320 bytes
interface FastEthernet0/0
description Customer LAN
ip address 10.10.10.251 255.255.255.0
load-interval 30
duplex auto
speed auto
no cdp enable
glbp 10 ip 10.10.10.3
glbp 10 weighting 100 lower 91 upper 99
glbp 10 weighting track 1
end
Thank you.
Goutam Sanyal
Level 4
Level 4
Hi, As per Cisco "Another system is using your IP address.
Recommended Action: Change the IP address of one of the two systems"
Also requesting you to check the "HSRP/GLPB" configuration, if its configured.
Goutam
Pls rate if t helps you
Thanks for your reply.
From the 'show arp', can see different ip addresses share one mac address, it's not normal, seems to me like ARP attack, do you have any experience to deal with this kind of problem?
Thank you,
Hi, Previously at the time of deploying the "HSRP" we have faced the same problem. That time we found a switching loop at our network with our management VLAN. So check your VLAN configuration as well as STP status of your switch fabric. As well as check any switching loop as present or not. Thanks Goutam (Pls rate if I am informative)
smothuku
Level 7
Level 7
Hi ,
Can you claer CAM table using clear mac-address-table dynamic command ...Check the issue after clearing the CAM.
Thnaks,
Satish
