Failed DDNS configuration
bellaireroad
I am attempting to configure DDNS on an 1811W, but my configuration fails.  Apparently,it is not connecting to the TZO server, because when I run <show ip ddns update> in telnet, the message "update destination not available, although rh.tzo.com can be pinged.  I am attaching a copy of the config file.  the ip name-server entries are my IP DNS, and the url/user name/ key entry was provided by TZO support.  Would appreciate any thoughts. Thanks. Roger
Building configuration...
Current configuration : 5325 bytes
version 12.4
hostname cisco
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool sdm-pool1
  import all
  network 192.168.1.0 255.255.255.0
  default-router 192.168.1.1
  lease infinite
no ip ftp passive
ip name-server 68.113.206.10
ip name-server 24.217.0.5
ip ddns update method TZO
HTTP
  add http://rh.tzo.com/webclient/tzoperl.html?TZOName=<SNIP>t&Email=<SNIP>&TZOKey=<SNIP>=Sign+On
interval maximum 0 0 15 0
bridge irb
interface FastEthernet0
description $ETH-WAN$
ip ddns update TZO
ip address dhcp client-id FastEthernet0
ip nat outside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
interface FastEthernet1
description $ETH-LAN$
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 2
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Vlan1
no ip address
no ip route-cache
bridge-group 2
interface BVI2
ip nat inside
no ip route-cache
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
johnlloyd_13
Level 9
Level 9
try to add below and test again.
access-list 1 permit 192.168.1.0 0.0.0.255
Sorry, I clipped out part of the config to abbreviate it.  I am a novice studying for CCNA.  Here is the complete config. the ACL is part of the config.  Does anyone see what might be wrong here?  thanks
version 12.4
hostname cisco
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 @@@@@@@@@@@@@@@
enable password @@@@@@
no aaa new-model
resource policy
!Building configuration...
vesion 12.4
hostname cisco
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
no ip cef
import all
lease infinite
ip dhcp pool SERVER
host 192.168.1.111 255.255.255.0
client-identifier @@@@@@@@@
client-name SERVER
ip dhcp pool SUPERMICRO
host 192.168.1.11 255.255.255.0
client-name SUPERMICRO
no ip ftp passive
HTTP
add http://rh.tzo.com/webclient/tzoperl.html?TZOName=@@@@@@@&Email=@@@@@@@@t&TZOKey=@@@@@@@@@&B1=Sign+On
crypto pki trustpoint TP-self-signed-@@@@@@@@@
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-@@@@@@@@
revocation-check none
rsakeypair TP-self-signed-@@@@@@@@@
crypto pki certificate chain TP-self-signed-@@@@@@@@@
certificate self-signed 01
username @@@@@@@@ privilege 15 secret 5 @@@@@@@@@@.
bridge irb
ip ddns update hostname rh.tzo.com
ip ddns update TZO
ip nat outside
no ip route-cache
duplex auto
speed auto
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 2
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface FastEthernet9
shutdown
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size @@@@@@@@@
encryption mode wep mandatory
ssid CISCO
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 2
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption key 1 size @@@@@@@@@@@ transmit-key
ssid CISCO
authentication open
guest-mode
station-role root
bridge-group 2
interface Vlan1
no ip address
no ip route-cache
bridge-group 2
interface Async1
no ip address
encapsulation slip
no ip route-cache
interface BVI2
ip nat inside
no ip route-cache
ip http server
access-list 1 remark INSIDE_IF=BVI2
access-list 1 remark SDM_ACL Category=2
dialer-list 1 protocol ip permit
control-plane
bridge 2 protocol ieee
bridge 2 route ip
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
privilege level 15
password @@@@@@
login local
transport input telnet ssh
webvpn context Default_context
ssl authenticate verify all
no inservice
end
for what its worth, I got this running by adding the line to the config, and removing the entries.  Maybe this will hepl someone else trying to set this up
