ipv6 on a bvi interface
dhalevi
hi all,
I am having trouble setting an ipv6 address on a bvi interface.  My setup is the following
                                            npe-g1
                                        2821        sup720
The I have int gi0/1 and gi0/2 on the npeg1 as members of bridge-group 1.
The 2821 is connected to int gi0/1.  The sup720 is connectot int gi0/3 which is not part of the bridge-group.
I can ping the ipv6 address of the bvi from the sup720.  But I can't ping the bvi interface from the 2821.
Can anyone please give me some input on why I can't ping the BVI Global unicast address from the 2821?  thanks in advance!
The config on the npe-g1 is the following
ipv6 unicast-routing
bridge irb
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
no negotiation auto
ipv6 enable
bridge-group 1
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
media-type rj45
no negotiation auto
ipv6 enable
bridge-group 1
interface GigabitEthernet0/3
no ip address
duplex auto
speed auto
media-type rj45
no negotiation auto
ipv6 address 2001:DB8:C17:1::/64 eui-64
ipv6 enable
interface BVI1
ip address 1.1.1.1 255.0.0.0
ipv6 address 2001:DB8:C18:1::/64 eui-64
ipv6 enable
bridge 1 priority 50000
bridge 1 protocol ieee
bridge 1 route ip
GigabitEthernet0/3 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::201:C9FF:FE74:7C19
  No Virtual link-local address(es):
  Global unicast address(es):
    2001:DB8:C17:1:201:C9FF:FE74:7C19, subnet is 2001:DB8:C17:1::/64 [EUI]
  Joined group address(es):
    FF02::1
    FF02::2
    FF02::1:FF74:7C19
  MTU is 1500 bytes
  ICMP error messages limited to one every 100 milliseconds
  ICMP redirects are enabled
  ICMP unreachables are sent
  ND DAD is enabled, number of DAD attempts: 1
  ND reachable time is 30000 milliseconds
  ND advertised reachable time is 0 milliseconds
  ND advertised retransmit interval is 0 milliseconds
  ND router advertisements are sent every 200 seconds
  ND router advertisements live for 1800 seconds
  ND advertised default router preference is Medium
  Hosts use stateless autoconfig for addresses.
BVI1 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::201:C9FF:FE74:7C1B
    2001:DB8:C18:1:201:C9FF:FE74:7C1B, subnet is 2001:DB8:C18:1::/64 [EUI]
    FF02::1
    FF02::2
    FF02::1:FF74:7C1B
  MTU is 1500 bytes
  ND DAD is not supported
12 Replies 12
Mohamed Sobair
Level 7
Level 7
What IP Address configured on the 2821 facing G0/1 interface , pleae post its configuration here.
Mohamed
hi Mohamed,
Thanks for replying.  The config on the 2821 is as follows,
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
ipv6 enable
ipv6 route ::/0 2001:DB8:C17:1:201:C9FF:FE74:7C19
cisco2821# sho ipv6 int gi0/0
GigabitEthernet0/0 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::21D:A1FF:FE88:4B08
    2001:DB8:C17:1:21D:A1FF:FE88:4B08, subnet is 2001:DB8:C17:1::/64 [EUI]
    FF02::1
    FF02::2
    FF02::1:FF88:4B08
  MTU is 1500 bytes
  ND reachable time is 30000 milliseconds (using 25831)
  ND advertised reachable time is 0 (unspecified)
  ND advertised retransmit interval is 0 (unspecified)
cisco2821#
thanks!
the Interface of the 2821 is on different subnet from the BVI interface, you will need to do the following on the 2821:
interface G0/0
You should now be able to ping the BVI interface.
Note:
Dont forget to change your default route on the 2821 to the BVI IPv6 address.
Mohamed
hi Mohamed,
Sorry, I got confused with the interfaces.  It is the 6500 that is connected to the bvi.
npe-g1#sho cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                          S - Switch, H - Host,   I - IGMP,   r - Repeater
Device ID          Local Intrfce     Holdtme    Capability   Platform  Port ID
6500                 Gig 0/1            132          R S I           WS-C6509  Gig 5/2
cisco2821         Gig 0/3             140          R S I           2821      Gig 0/0
npe-g1#sho ipv6 neighbors
IPv6 Address                                                       Age Link-layer Addr State Interface
2001:DB8:C17:1:21D:A1FF:FE88:4B08                     2 001d.a188.4b08  STALE Gi0/3
FE80::21D:A1FF:FE88:4B08                                    2 001d.a188.4b08  STALE Gi0/3
FE80::2D0:4FF:FE51:2C00                                     10 00d0.0451.2c00  STALE Gi0/1
6500#sho ipv6 neighbors
FE80::201:C9FF:FE74:7C1B                         1 0001.c974.7c1b  STALE GigabitEthernet5/2
6500#sho ipv6 int gi5/2
GigabitEthernet5/2 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::2D0:4FF:FE51:2C00
    2001:DB8:C18:1:2D0:4FF:FE51:2C00, subnet is 2001:DB8:C18:1::/64
    FF02::1
    FF02::2
    FF02::1:FF51:2C00
  MTU is 1500 bytes
6500#
config on 6500
interface GigabitEthernet5/2
no ip address
media-type rj45
ipv6 enable
ipv6 route ::/0 2001:DB8:C18:1:201:C9FF:FE74:7C1B
when I try to ping the Global unicast address of the bvi interface
6500#ping 2001:DB8:C18:1:201:C9FF:FE74:7C1B
Sending 5, 100-byte ICMP Echos to 2001:DB8:C18:1:201:C9FF:FE74:7C1B, timeout is 2 seconds:
Success rate is 0 percent (0/5)
when I try to ping the link-local address of the bvi it works
6500#ping FE80::201:C9FF:FE74:7C1B
Output Interface: Gigabitethernet5/2
Sending 5, 100-byte ICMP Echos to FE80::201:C9FF:FE74:7C1B, timeout is 2 seconds:
Strange !!
from the output of sh ipv6 nei, we can see that ICMP neighbor is discovering an IPv6 neighbor, yet you cant ping a global Ipv6 address.
Can you post the output from (debug icmp) and try to ping the global address again.
Mohamed
here it is,
6500#debug ipv6 icmp
ICMP packet debugging is on
1d01h: ICMPv6: Sending echo request to 2001:DB8:C18:1:201:C9FF:FE74:7C1B.
I turned it on the npe-g1 also, and I get,
npe-g1#debug ipv6 icmp
npe-g1#
Apr 20 08:15:23.285: ICMPv6: Received ICMPv6 packet from FE80::21D:A1FF:FE88:4B08, type 134
Apr 20 08:18:09.865: ICMPv6: Received ICMPv6 packet from FE80::21D:A1FF:FE88:4B08, type 134
This was without ipv6 enable on int gi0/1, which is a member of the bvi.  Putting ipv6 enable on int gi0/1 i only get,
1d02h: ICMPv6: Sending echo request to 2001:DB8:C18:1:201:C9FF:FE74:7C1B.
6500#
I get no messages on the npe-g1.
update, the messages on the npeg1, Apr 20 08:15:23.285: ICMPv6: Received ICMPv6 packet from FE80::21D:A1FF:FE88:4B08, type 134
are coming from the 2821 which is connected to gi0/3, which is not a member of the bvi.  The ipv6 above is the link local address of the 2821 interface.
there is no reason for this to happen, and Since you have local communication between link-local addresses. However, I would again check my IPv6 assigned addresses of the interfaces (Bvi & 6500). I still not sure if the interface's IPv6 GLobal Addresses are correctly configured?
Mohamed
Hi Mohamed,
As a sanity check I took int gi0/1 out of the bridge group and gave it the global unicast address.  Doing this I was able to ping from the 2821 across the npe-g1 to the 6500.  I have now added int gi0/1 to the bridge group, but I have left the global unicast addess on int gi0/1 and not on the BVI 1 interface.
It now seems to be working ok.  I can ping accross the npe-g1.  Is it wrong to put the unicast global address on the BVI 1 interface?
6500# ping 2001:DB8:C17:1:21D:A1FF:FE88:4B08
Sending 5, 100-byte ICMP Echos to 2001:DB8:C17:1:21D:A1FF:FE88:4B08, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Sending 5, 100-byte ICMP Echos to 2001:DB8:C18:1:2D0:4FF:FE51:2C00, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/0/4 ms
2001:DB8:C17:1:21D:A1FF:FE88:4B08           0 001d.a188.4b08  REACH Gi0/3
2001:DB8:C18:1:2D0:4FF:FE51:2C00            0 00d0.0451.2c00  REACH Gi0/1
FE80::21D:A1FF:FE88:4B08                    0 001d.a188.4b08  REACH Gi0/3
FE80::2D0:4FF:FE51:2C00                     0 00d0.0451.2c00  REACH Gi0/1
npe-g1#sho run int gi0/1
Building configuration...
Current configuration : 184 bytes
no ip address
duplex auto
speed auto
media-type rj45
no negotiation auto
ipv6 enable
bridge-group 1
end
npe-g1#sho run int bvi 1
Current configuration : 50 bytes
interface BVI1
no ip address
ipv6 enable
end
Its indeed wrong to put the IPv6 GLobal Address on a bridged Interface of the router, and I am wondering how it works with you, that means your bridging between interfaces is not working.
A router has a Layer-3 port , these ports are the ports that needs and IP or IPv6 addresses to start forwarding packets, Once you assign a port as part of a bridge Group, You actually instructing it to become a bridged port NOT  a layer-3 port and cant be used directly to forward IPv6 or IP packet.
What IOS Software version you are running? Let me check if this is not an IOS or bug related issue.
Mohamed
hi Mohamed,
I am using, C7200-ADVIPSERVICESK9-M), Version 12.4(9)T
I thought that I would have to have the global address on the BVI interface.  I was thinking that this would be the address of the default gateway for all the devices connected to the BVI.  I was hoping to have some redundancy for the switches that will connect to the BVI.
Doron
Hi Doron,
Yes you are correct about what you mentioned, and its actually how it should behave. I apologize as I dont have the right Access now for (Bug Toolkit) to search on known Software bugs for C7200 12.4(9)T, Please check bellow link and let us know if you find some thing related.
www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl
Mohamed
I think you need IOS 15.1(3)T or later for this capability.  CSCta27529.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCta27529
