failover between 2 links
shivathapa
Dear All,
Customer has 2 link connected between 2 different distribution point thru optical fiber. same ip address is configured at both the end routers. Current situation is that one link is in shut mode till his running link goes down. he want the link to be automatically switch if one link goes down. Is there any solution to it as the client is irectly connected to his PC thru non manageable 4 port switch. plz help
for ur info both the fiber from 2 diff. point is conencted to switch via media convertor..
Laurent Aubert
You can use the backup interface feature:
http://www.cisco.com/en/US/docs/ios/12_0/dial/command/reference/drdbaks.html
Laurent.
