failover by EIGRP for 2 ipip tunnels
hello
I have question about how to have failover solution when I am using 2 IPIP tunnels to connect a single router.
I can not figure it out  what network to advertise in EIGRP.
and now I am using static routing which is not efficient and I do not have failover on my sites.
my configuration on my customer side is :
interface Tunnel122
 ip address 10.0.1.18 255.255.255.252
 ip mtu 1439
 ip tcp adjust-mss 1439
 tunnel source 88.19.5.34
 tunnel destination 46.36.112.5
 tunnel mode ipip0
interface Tunnel123
 ip address 10.0.2.18 255.255.255.252
 ip mtu 1439
 tunnel destination 94.182.20.11
 tunnel mode ipip0
and my Head Quarter configuration :
interface Tunnel122
 ip address 10.0.1.17 255.255.255.252
 ip mtu 1439
 tunnel source 46.36.112.5
 tunnel destination  88.19.5.34
 tunnel mode ipip0
interface Tunnel123
 ip address 10.0.2.17 255.255.255.252
 ip mtu 1439
 tunnel source 94.182.20.11
 tunnel mode ipip0
When doing GRE tunnels and a routing protocol you have to be very careful. You can inadvertently advertise the interfaces that are the endpoints into the tunnel which makes the tunnels crash. I have found it very helpful and a best practice to put the transport underlay network into a separate VRF. This link is about DMVPN, but it also talks about the concept of an underlay network in a VRF. https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_conn_dmvpn/configuration/xe-16/sec-conn-dmvpn-xe-16-book/sec-conn-dmvpn-mtt.html
The other thing I would say is to keep all the tunnels up all the time, but weight them (on both sides) with the interface level "bandwidth" and/or interface level "delay" commands. Neither of those commands affect forwarding rates. They are only used for routing protocol metric calculation. I wouldn't load balance across the tunnels because the different paths could have widely varying delays which could put a load onto the hosts to reassemble out of order packets. You can try load balancing across multiple paths, but beware of that.
