Fastethernet Flap
cisconoval
If fastethernet is flapping frequently then what could be the issue...? how to fix it.
Please help me
get_shanu
Recommend you to check your media first and then workout to find out if your interface is getting Jumbo packets. Larger packets sometime cause the problem..
Thanks for your reply
Can you please tell is there any software to check the packets?
You can check the load of the interface with the help of "Show interface" command.
You can find the Rx & Tx of the interface.
Please rate if it does help.
Ajeet
kumar.ajeet
In a first look it seems there could be loose contact or might be the ethernet port has gone bad.
You can use "debug fastethernet {events | packets}" command for more information.
Please rate if it does help,
Ajeet Kumar
