fault tolerant internet connection
Hi ,
I have the following configuration on a cisco 2821 with two ADSLoISDN HWICs.
All HTTP traffic flows through Dialer0. All other traffic is routed through Dialer2.
What we want to do is, when connection through dialer0 is down to use Dialer2 for HTTP traffic.
Can anyone help?
Thanks in advanced.
interface GigabitEthernet0/0
description $ETH-LAN$
ip address 1.1.1.1 255.255.255.248   (public IP address)
ip nat inside
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
interface Dialer2
ip mtu 1452
ip nat outside
ip route 0.0.0.0 0.0.0.0 Dialer2
ip nat inside source route-map HTTP2Vivo interface Dialer0 overload
ip access-list extended HTTP-REQ
permit tcp any any eq www
permit udp any any eq domain
permit tcp any any eq domain
route-map HTTP2Vivo permit 10
match ip address HTTP-REQ
set interface Dialer0
How can I use the track command with route-map so that when Dialer0 is down to route HTTP traffic from Dialer2?
Thanks.
