Filter ::/0 EIGRP out interface
sebastien3
Level 4
Level 4
With EIGRP IPV6 I want to redistribute the static and connected routes but not the
default route ::/0
distribute-list prefix-list FILTER_EIGRP out GigabitEthernet1/0
redistribute static
redistribute connected
ipv6 prefix-list FILTER_EIGRP seq 10 deny ::/0
ipv6 prefix-list FILTER_EIGRP seq 20 permit ::/0 le 128
interface Loopback0
no ip address
ipv6 address 2001:db8:1:1:1:1:1:100/128
ipv6 enable
If I use the FILTER_EIGRP filter it works for the
default route ::/0
but not with an IPV6 of loopback0 which is in (LC) Local/Connected.
This filter rule work for a subnet IPV6 /64 Static (S).
How would you write the filtering
access list FILTER_EIGRP
Hi @sebastien3 ,
 It definitely appears to be an
eigrpv6
implementation difference.
As can be seen below, the
lo0 ipv6
address is flagged as "Connected" in the topology database, while the
lo0 ipv4
Rconnected
(or redistribute connected). This is most likely why only
stub redistributed
is sufficient with IPv4 to advertise the
lo0
address, while
stub redistributed connected
is required with IPv6.
DUT#sh ip eigrp topo
EIGRP-IPv4 VR(EIGRP) Topology Table for AS(10)/ID(192.168.100.1)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 192.168.100.1/32, 1 successors, FD is 163840
        via Rconnected (163840/0)
DUT#sh ipv6 eigrp topo
EIGRP-IPv6 VR(EIGRP) Topology Table for AS(10)/ID(10.10.10.229)
P 2001:DB8:1:1:1:1:1:100/128, 1 successors, FD is 163840
        via Connected, Loopback0
18 Replies 18
@sebastien3
 Try this way
ipv6 prefix-list FILTER_EIGRP seq 15 deny  ::100/128
@Flavio Miranda: Sorry this not work... IPV6 of Loopback does not propaged via EIGRP process.
@sebastien3  I believe  I misunderstood your problem. I thought  it was propagating despite the
prefix-list
and then I suggested deny the final ::100.
Try to do the opposite then, which is permit the final ::100. And keep the deny at the end.
ipv6 prefix-list FILTER_EIGRP seq 10 permit::100/128
ipv6 prefix-list FILTER_EIGRP seq 30 deny ::/0
The
default route ::/0
is still propagated even with this rule ! It doesn't have to be.
Hi @sebastien3 ,
The
prefix-list
is correct and should deny the
default route
and allow everything else.
What IOS version are you running?
Can you provide the output for the following command:
sh ipv6 prefix-list FILTER_EIGRP 2001:DB8:1:1:1:1:1:100/128 first-match
Hi @Harold Ritter
I use Version 15.2(4)M11, RELEASE SOFTWARE (fc2)
>The
prefix-list
default route
What
prefix-list
are you talking about to be sure ?
RTR#sh ipv6 prefix-list FILTER_EIGRP 2001:db8:1:1:1:1:1:100/128 first-match
seq 20 permit ::/0 le 128 (hit count: 15, refcount: 0)
RTR#sh ipv6 prefix-list FILTER_EIGRP ::/0 first-match
seq 10 deny ::/0 (hit count: 9, refcount: 1)
Hi @sebastien3 ,
I would definitely try with a more recent version
> What
prefix-list
You only mentioned one
prefix-list, FILTER_EIGRP
The first entry (seq 10) denies the
default route
and the second one (seq 20) allows everything else.
The results from the show commands proof that the
prefix-list
works as it should.
sebastien3
Level 4
Level 4
@Harold Ritter
prefix-list
works as it should.
Yes but no ! I don't understand... On the second EIGRP router I do not receive the
prefix 2001:db8:1:1:1:1:1:100/128
from router where I have the
prefix-list FILTER_EIGRP !!
Hi @sebastien3 ,
That is why I think that it might be related to the version you are running.
I just tried a quick test with 15.9(3)M4 and it works like a charm.
Can you provide the output for the following command from the advertising router:
show ipv6 eigrp topo
Hi @Harold Ritter
RTR#sh ipv6 eigrp topo
P FD00:10:6:60::/64, 1 successors, FD is 655360
via Connected, Port-channel1
P 2001:db8:10:13::/64, 1 successors, FD is 6554255360
via Rstatic (6554255360/0)
P FD00:10:0:113::2/128, 1 successors, FD is 163840
via Connected, Loopback10
P ::/0, 1 successors, FD is 131072
via Rstatic (131072/0)
P 2001:db8:1:1:1:1:1:100/128, 1 successors, FD is 163840
Hi @sebastien3 ,
I just wanted to verify that the
Lo0 ipv6
address is seen in the eigrp topology. It should definitely work. I would definitely recommend moving to a newer IOS version at this point.
Hi @Harold Ritter
I tested this same configuration with another router (ASR 1001 Cisco IOS XE Software, Version 03.16.10.S) and I have the same problem...
I do not understand why.
My first test is on a 7201 router, which is old (The IOS is the last possible) I admit but I have the same behavior with an ASR 1001.
Hi @sebastien3 ,
Thanks for the additional information. As I mentioned, I tested this successfully with 15.9(3)M4, but it might be that my configuration is different than yours, as you only provided partial configurations.
Do you have any filters on the receiving routers?
Could you share more information about the configuration of the advertising router. as the
prefix-list
is not the issue as we have already verified.
Hi @Harold Ritter ,
Here is the EIGRP IPV6 configuration between the router (7201) and the switch (4500).
I also tried with an ASR1001 and a 4500 switch with the same config. I have the same problem 😞
### Router1 (C7200P-ADVENTERPRISEK9-M), Version 15.2(4)M11
interface Loopback0
no ip address
ipv6 enable
interface GigabitEthernet1/0
description To SWITCH-2 4500
ipv6 address FD00:10:6:60::13/64
ipv6 enable
no ipv6 redirects
router eigrp EIGRP
address-family ipv6 unicast autonomous-system 10
af-interface default
passive-interface
exit-af-interface
af-interface GigabitEthernet1/0
no passive-interface
exit-af-interface
topology base
redistribute static
exit-af-topology
eigrp router-id 10.10.10.229
eigrp stub redistributed
exit-address-family
ipv6 route ::/0 FD00:10:6:60::14
### SWITCH-2 Version 03.11.08.E
interface Vlan15
description To Router1 7201
ipv6 address FD00:10:6:60::14/64
ipv6 enable
no ipv6 redirects
end
router eigrp EIGRP
passive-interface
exit-af-interface
af-interface Vlan15
exit-af-interface
topology base
distribute-list prefix-list FILTER_EIGRP out Vlan15
redistribute static
exit-af-topology
eigrp router-id 10.10.10.113
nsf
exit-address-family
Thanks !
