Filter Netflow to only send specifc flows from/to certain subnets
Isaac Smith
We are testing out a new NPM solution for a specifc project.  Right now we have all our netflow (netflow9) flows pointing to our scrutinizer box.  The new NPM box is small and can only handle so many flows per second.  We're trying to figure otu a way to have it so flows get exported to a secondary collector but only those flows that match 4 specific subnets.  I would assume there would be a way to do it via an ACL/Class maps but documentation for this specific thing is hard to cipher.
Any ideas?
Currently this is our netflow setup that is sending all flows to a specific collector:
X.X.X.X is the current main flow collector for all our enterprise - Y.Y.Y.Y is the new flow collector that can only handle so many flows and we only want to filter flow data to only send if traffic matches specific subnets.  We have WAN optimizers inline on half of our offices that can do this easily with a click of a button and specifying the subnets but can't figure out how to do this via a router.
flow record TCP-UDP
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 match ipv4 tos
 match flow direction
 match application name
 collect interface output
 collect routing source as
 collect routing destination as
 collect routing next-hop address ipv4
 collect ipv4 dscp
 collect ipv4 id
 collect ipv4 ttl
 collect ipv4 ttl minimum
 collect ipv4 source prefix
 collect transport tcp source-port
 collect transport tcp destination-port
 collect transport tcp sequence-number
 collect transport tcp flags
 collect transport udp source-port
 collect transport udp destination-port
 collect counter bytes
 collect counter packets
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
 collect timestamp absolute first
 collect timestamp absolute last
 collect timestamp absolute monitoring-interval start
flow exporter COMPANY-Flow
 description FNF-Exporter
 destination X.X.X.X
 source Loopback0
 dscp 16
 transport udp 2055
 template data timeout 60
 option interface-table timeout 60
 option exporter-stats timeout 60
 option vrf-table timeout 60
 option application-table timeout 60
 option application-attributes timeout 60
flow exporter COMPANY-Flow-Profiler
 destination Y.Y.Y.Y
 source Loopback0
 dscp 16
 transport udp 2055
flow monitor TCP-UDP
 cache timeout active 60
 cache entries 25000
 statistics packet protocol
 record TCP-UDP
Giuseppe Larosa
Hello Isaac,
support for multiple collectors (2) was added for some platforms, but a selective sending based on IP subnet of the observed flow to a single collector server is something new to me.
I don't think there is a way to achieve this.
see
NetFlow Multiple Export Destinations: Benefits
The NetFlow Multiple Export Destinations feature enables configuration of multiple destinations for the NetFlow data. With this feature enabled, two identical streams of NetFlow data are sent to the destination host. Currently, the maximum number of export destinations allowed is two.
The NetFlow Multiple Export Destinations feature improves the chances of receiving complete NetFlow data because it provides redundant streams of data. Because the same export data is sent to more than one NetFlow collector, fewer packets are lost.
http://www.cisco.com/c/en/us/td/docs/ios/netflow/configuration/guide/12_2sr/nf_12_2sr_book/cfg_nflow_data_expt.html#wp1057619
Hope to help
Giuseppe
I had opened a ticket with TAC and they suggested a solution involving matching an ACL but I haven't gotten a chance to test it out. If I ever get around to it I'll update this.
