Flexible Netflow ISR 4451
dotansplus
Hello
I tried to configure netflow in a ISR4451, but in solar winds I have this error: "details for interface gi0/0/0 on router-test are not available because netflow and CBQos data are not available.
This is the configuration:
flow record v4_r1
 match ipv4 tos
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 collect counter bytes long
 collect counter packets long
flow exporter EXPO1
 destination x.x.x.x
 transport udp 90
flow monitor FLOWMON1
 exporter EXPO1
 record v4_r1
interface GigabitEthernet0/0/0
 ip address y.y.y.y z.z.z.z
 ip flow monitor FLOWMON1 input
 ip flow monitor FLOWMON1 output
What am I missing?.
milan.kulik
Level 10
Level 10
Hi, IMHO, you are not sending the info which interface was detecting the flow to your collector. You'd need to add match interface output/input commands to your flow record configuration. But as SolarWinds collector is a non-Cisco product, I'd recommend using predefined traditional records ("record netflow ipv4 original-input", e.g.) within your flow monitor configuration. See http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fnetflow/configuration/15-mt/fnf-15-mt-book/fnf-fnetflow.html#GUID-96190B11-23AC-4A08-9D85-D552616596D6 for details. Last but not least: Are you sure your collector is configured to receive NetFlow on UDP port 90? Best regards, Milan
Hello Milan, thanks for the reply.
the match interface output/input to my flow record is the gi0/0/0 witch I had this commands:
is that what are you refering?.
Yes, our collector is configured to receive NetFlow on UDP port 90.
Thanks!.
no, what I meant was
flow record v4_r1
match interface input
in your config.
But as I said, I'd recommend to use
instead of your customized record.
Best regards,
Milan
