switch help FOR BUYING
andrewpaulsen
 what switchs would anyone recommend for the following setup? i need a switch that does the following 10 gig SFP+ Uplinks, 10/100/1000 copper x20 or more and 6+ SFP gig fiber.
Leo Laohoo
10 gig SFP+ Uplinks
How many SFP+ ports do you require?
If you want this cheap, you won't find a single-unit-appliance.  You're looking at two units and stacked.  Like WS-C3750X-24TS (24-copper ports) and stacked with WS-C3750X-12S (12-SFP ports).  For SFP+, the 3750X can also support C3KX-NM-10G which brings you two SFP+ port to a single unit of 3750X.
Take note that I am not recommending 3850 switches (even though they have the same price as the 3750X) for the following reasons:
1.  I don't know the network you're planning to deploy the switches to; and
2.  3850 is still very unstable.
thanks for get backing to me on this topic
the SFP+ i need 2 of. At the current moment i believe i have found a solution that will fit within my budget by using sfp media converters to take a couple of the standard sfp's and convert them to copper.
