Flexible Netflow
Daniel Smith
I need to move to Netflow V9, and am not sure if I am heading down the right path. I have the following config in place, and am generating test flows with a Smartbits. However, I never see the router export a net flow packet. Any ideas?
flow record test-flow-name
match ipv4 tos
match ipv4 dscp
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
match interface output
collect transport icmp ipv4 type
collect transport icmp ipv4 code
collect transport tcp source-port
collect transport tcp destination-port
collect transport tcp flags
collect transport udp source-port
collect transport udp destination-port
collect transport udp message-length
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter test-harvester
destination 10.92.99.121
source Loopback0
template data timeout 60
flow monitor test-monitor
record aep-flow-name
exporter aep-harvester
cache timeout active 60
interface GigabitEthernet0/2
ip address 10.41.22.254 255.255.255.0
ip flow monitor test-monitor input
ip flow monitor test-monitor output
duplex auto
speed auto
skarthic
source Loopback0
exporter aep-harvester -------->
Shdn't the exporter name be "test-harverster" ?
Please try changing "exporter aep-harvester" to "test-harvester". The exported command must have
one of the flow exporters name.Or do u have an exporter with name "aep-harvester".
Regards.
I had tried to sanitize the config before posting and missed that one line. The line should read 'test-harve
ster'. However, with that config in place. No luck. IN order to get Netflow packets to be exported, I had to add in some global commands:
ip flow-cache entries 50000
ip flow-cache timeout active 1
ip flow-export source Loopback0
ip flow-export version 9
ip flow-export destination 10.92.99.121 9995
Which to me seems to bypass the flow exporter configuration.
I think the destination port is not defined in the flow exporter which is why NetFlow is not being exported. Set the export port in the exporter using the command 'transport udp 9996' (9996 is the default port for ManageEngine) and then check the issue. You may need to remove the flow exporter from the monitor to edit it.
Don Thomas
ManageEngine NetFlow Analyzer
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
