Forward Port 80???
cbaker
I would like to obtain some info on how to set up a Cisco 1841 router to have the external serial interface forward Port 80 requests to an internal address (web server).
I guess I would be asking for is the command line structure to do so...
Thanks a Bunch
8 Replies 8
pkhatri
Level 11
Level 11
Try this:
interface FastEthernet0/0
ip address 10.1.1.1 255.255.255.0
ip nat inside
interface Serial0/1
ip address 200.1.1.1 255.255.255.0
ip nat outside
ip nat inside source static tcp 10.1.1.10 80 serial0/1 80
This will forward all port 80 HTTP requests to the serial interface IP address to the server at 10.1.1.10
Paresh
Thanks a bunch...
One more little one, I want to install the SDM utility on this router and noticed that I need to turn on HTTP...currently this is what I see in the config:
no ip http server
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
Since it says: No ip http server I am assuming it is turned off? How can I turn it back on?
Thanks Again
Give following commands:
username cisco privilege 15 secret 0 cisco
ip http server
ip http secure-server
line con 0
login local
line vty 0 4
privilege level 15
login local
line vty 5 15
privilege level 15
login local
Hope that helps.
Pls rate all posts.
JD
The command did not work?
Let me clarify
The following command will not work as listed:
I get an invalid input detected under the S in Source
Do I need to break this down as follows:
ip nat inside
then...
desai.jaideep
Level 5
Level 5
(1)Have u already enabled NAT?If not then the commands are:
int s0
ip nat outside
int e0
ip add x.x.x.y 255.255.255.0
ip nat inside
access-list 1 permit x.x.x.0 0.0.0.255
ip nat inside source list 1 interface s0 overload
(2)The port forwarding is done as following.
ip nat inside source static tcp x.x.x.z 80 x.x.x.a 80 extendable
Pls rate helpful posts.
JD
Yes NAT is enabled and running on both interfaces as to the similar config above.
Try this then:
Try this:
ip nat inside
interface Serial0/1
ip nat outside
ip nat inside source static tcp 10.1.1.10 80 200.1.1.1 80
Paresh
