2600 Router
kthned
Level 3
Level 3
I am going to buy 2600 router
CISCO2621XM Mid Perf Dual 10/100 Ethernet Router w/Cisco IOS IP,32F/128D
But i am not sure that have it the serial port, as i hav to connect it to my 2500 series router.
or should i have to buy wic card??
desai.jaideep
Level 5
Level 5
(1)The router has 2 WIC slots and one NM slot.You need to purchase seperate serial card.
(2)If u are connecting directly to the 2500 router then u need a WIC-1T card on it.
Pls rate helpful posts.
JD
A note on buying 2600xm routers. Make sure you ask if it has the bootflash at 12.2(8r) or higher. This bootflash allows you to put 256m of ram in the router which you will need if you plan to run the newest IOS levels. If this is not a used router then you will be ok.
Even though cisco says there is software support though mar/2010 on 2600xm they neglet to say that it won't fit unless you have this bootrom
Hey tdrais, how would I upgrade a 2600XM series router to bootflash 12.2(8r) or higher and the memory to 256m from 128m ?
Is it possible ?
Okay I checked this one out, you can buy a bootflash and memory here,
http://www.anthonypanda.com/product.php?prd_id=171&opt_id=241
