Route-Map ?
chintu_punjabi
Below is the pasted configuration of one router, problem is route map not working. it is not doing source based routing. Packets from specific source are (LAN pool) are taking default route only.
Any idea or i am missing something ?
ip cef
interface Loopback0
no ip address
interface Serial0
ip address 61.95.141.122 255.255.255.252
interface Serial1
ip address 203.187.240.254 255.255.255.252
interface FastEthernet0
ip address 203.101.119.209 255.255.255.240 secondary
ip address 203.187.240.1 255.255.255.240 secondary
ip address 203.101.81.33 255.255.255.248
ip policy route-map Iqara
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 61.95.141.121
ip route 203.187.192.12 255.255.255.255 203.187.240.253
ip route 203.187.192.15 255.255.255.255 203.187.240.253
no ip http server
access-list 110 permit ip host 203.187.240.2 any
access-list 110 permit ip 203.187.240.0 0.0.0.15 any
access-list 191 permit icmp any any echo
access-list 191 permit icmp any any echo-reply
route-map Iqara permit 20
match ip address 110
set ip next-hop 203.187.240.253
7 Replies 7
mihanlin
What happens when you issue a show ip access-list 110
Do you see the counters incrementing for the access list when traffic passes over the ethernet interface?
Michael
yes, counters increase. But not on that rate on which packets are flowing i.e. if i try 100 times,access list shows 20 only.
Can you please provide the "sh ip route" ?
yan.yong
try to debug ip packet 110, past the output .
Below is the sh ip route output.
Gateway of last resort is 61.95.141.121 to network 0.0.0.0
203.101.81.0/29 is subnetted, 1 subnets
C 203.101.81.32 is directly connected, FastEthernet0
203.101.119.0/28 is subnetted, 1 subnets
C 203.101.119.208 is directly connected, FastEthernet0
203.187.240.0/24 is variably subnetted, 2 subnets, 2 masks
C 203.187.240.252/30 is directly connected, Serial1
C 203.187.240.0/28 is directly connected, FastEthernet0
203.187.192.0/32 is subnetted, 2 subnets
S 203.187.192.12 [1/0] via 203.187.240.253
S 203.187.192.15 [1/0] via 203.187.240.253
61.0.0.0/30 is subnetted, 1 subnets
C 61.95.141.120 is directly connected, Serial0
S* 0.0.0.0/0 [1/0] via 61.95.141.121
It might be worthing doing a 'debug ip policy' to see what exactly is happening.
Paresh
