Frame relay & Internet connection
wananga01
I have setup a Cisco 1721 router to connect via frame-relay to my service provider.
From the router I can ping anywhere including Domain names.
From my workstation I can ping both router interfaces but not across the frame-relay link and I cannot access the Internet.
mpabilona
Since you are using private ip addresses for your local network, I suggest you implement cisco NAT. Implementation would be like this:
interface FastEthernet0
ip address 10.2.0.101 255.255.0.0
ip nat inside
speed auto
interface Serial0
ip address 203.167.213.126 255.255.255.252
encapsulation frame-relay IETF
frame-relay map ip 203.167.213.125 149
frame-relay interface-dlci 149
ip nat outside
ip route 0.0.0.0 0.0.0.0 203.167.213.125
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit 10.2.0.0 255.255.0.0
Thanks I try this. Any idea if enabling NAT allow me to get access to the Interent from my work station?
Using your private lan ip through NAT, your internal workstations can access to internet via your default gateway.
wananga01
Thanks for your solution it worked which is simply great.
Much appreciated
