Frame-relay network
feroz syed
Level 3
Level 3
hi,
Router 1 has two DLCI 102 and 103, R1 can able to ping both R2 and R3 but from R2 to R3 or R3 to R2 has no ip connectivity.Any help would be great appreciate
Serial1/0 (up): ip 192.168.1.3 dlci 102(0x66,0x1860), static,
              broadcast,
              CISCO, status defined, active
Serial1/0 (up): ip 192.168.1.2 dlci 102(0x66,0x1860), static,
              broadcast,
You have an error in your static frame maps on R1, you configured both with  DLCI 102 so change accordingly on R1:
int s1/0
no frame map ip 192.168.1.3 102
frame map ip 192.168.1.3 103
Alain
12 Replies 12
cadet alain
you need  static mapping on each spoke for the other spoke:
let's suppose R2 is 192.168.1.2/24 and R3 is 192.168.1.3/24
so on R2:
int s1/0
frame-relay map ip 192.168.1.3 201 broadcast  I suppose you use DLCI 201 on R2
on R3:
int s1/0
frame-relay map ip 192.168.1.2 301 broadcast  I suppose you use DLCI 301 on R3
Alain
here is my config
R1
interface Serial1/0
encapsulation frame-relay
serial restart-delay 0
frame-relay map ip 192.168.1.3 103 broadcast
frame-relay map ip 192.168.1.2 102 broadcast
R1#sh frame-relay map
              broadcast,
Serial1/0 (up): ip 192.168.1.3 dlci 103(0x67,0x1870), static,
              broadcast,
R2
interface Serial1/0
ip address 192.168.1.2 255.255.255.0
frame-relay map ip 192.168.1.1 201 broadcast
interface Serial1/0
R3
interface Serial1/0
ip address 192.168.1.3 255.255.255.0
frame-relay map ip 192.168.1.1 301 broadcast
R3#sh frame-relay map
Serial1/0 (up): ip 192.168.1.2 dlci 301(0x12D,0x48D0), static,
              broadcast,
Serial1/0 (up): ip 192.168.1.1 dlci 301(0x12D,0x48D0), static,
              broadcast,
I have the same setup as you said, but still no ip connectivity
on R2:
conf t
logging on
logging console 7
no service timestamp debug
do debug frame pack
do ping 192.1638.1.3 rep 1
then post output  as well as following command output on all routers:
sh frame map
sh frame pvc | i DLCI
Alain
R2(config)#do ping 192.168.1.3 rep 1
Sending 1, 100-byte ICMP Echos to 192.168.1.3, timeout is 2 seconds:
Serial1/0(o): dlci 201(0x3091), pkt type 0x800(IP), datagramsize 104
Serial1/0(i): dlci 201(0x3091), pkt type 0x800, datagramsize 60
Serial1/0(i): dlci 201(0x3091), pkt type 0x800, datagramsize 104.
Success rate is 0 percent (0/1)
R3(config)#do ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Serial1/0(o): dlci 301(0x48D1), pkt type 0x800(IP), datagramsize 104.
Success rate is 0 percent (0/5)
R2(config)#do sh frame-relay map
Serial1/0 (up): ip 192.168.1.3 dlci 201(0xC9,0x3090), static,
              broadcast,
Serial1/0 (up): ip 192.168.1.1 dlci 201(0xC9,0x3090), static,
              broadcast,
R3(config)#do sh frame-relay map
              broadcast,
              broadcast,
R2(config)#do sh frame pvc | i dlci
R2(config)#
Hello
R1
int ser0/0
no frame-relay inverse-arp
clear frame inarp
R2
int ser0/1
no frame-relay map ip 192.168.1.3 201 broadcast
clear frame inarp
R3
int ser0/1
no frame-relay map ip 192.168.1.2 301 broadcast
clear frame inarp
"broadcast" keyword shouldn't be applied  from spoke to spoke  as the hub router ( in this case R1) will receive redundant route traffic.
You could also try disabling spilt-horizon in R1 - (no ip split-horizon)
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
I agree with you that it is best not to enable pseudobroadcast for same DLCI/L3 protocol on multiple static frame mappings but even doing it shouldn't have no influence on unicast ping from spoke to spoke.
You also clear the InvARP cache but this is only for dynamic mappings and I don't see any in the sh frame map outputs.
Alain
ok so this is not a L3/L2 encapsulation problem on the spokes.Can you post following on R1:
sh frame map
sh frame pvc
Can you ping from both spokes to the hub(r1) ?
also ping again from r2 to r3 and use this command on both routers: do debug ip icmp and post output.
Alain
Now can't able ping from R1 to R3.
              broadcast,
              broadcast,
R1#sh frame-relay pvc
PVC Statistics for interface Serial1/0 (Frame Relay DTE)
              Active     Inactive      Deleted       Static
  Local          1            0            0            0
  Switched       0            0            0            0
  Unused         1            0            0            0
DLCI = 102, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial1/0
  input pkts 226           output pkts 217          in bytes 22404
  out bytes 22084          dropped pkts 0           in pkts dropped 0
  out pkts dropped 0                out bytes dropped 0
  in FECN pkts 0           in BECN pkts 0           out FECN pkts 0
  out BECN pkts 0          in DE pkts 0             out DE pkts 0
  out bcast pkts 0         out bcast bytes 0
  pvc create time 00:36:00, last time pvc status changed 00:32:15
DLCI = 103, DLCI USAGE = UNUSED, PVC STATUS = ACTIVE, INTERFACE = Serial1/0
  input pkts 40            output pkts 26           in bytes 2410
  out bytes 884            dropped pkts 0           in pkts dropped 0
  out bcast pkts 26        out bcast bytes 884
  pvc create time 00:33:18, last time pvc status changed 00:32:18
              broadcast,
              broadcast,
int s1/0
Alain
feroz syed
Level 3
Level 3
Thanks for that correction, so what about from router 2 to router 3 can it ping by changing the dlci on router 1.
Sent from Cisco Technical Support Android App
It should be able to now but test it and if it is ok don't forget to rate the helpful post and mark your thread as resolved.
Alain
Thanks for your continues  fast reply
