frame-relay port adapter
flymen331
Hi all,
We are planing to leasing an 45Mbps Frame-relay circuits. Which port adapter can supported on CISCO 7206VXR platform?
Thanks Edison.
But if the bandwidth over 100Mbps, may I use PA-POS-OC3 or PA-A3-OC3? Which should be better?
What kind of physical hand-off are you going to receive from the provider?
The modules you mentioned above are for Packet-Over-Sonet and ATM Circuits respectively.
The module I mentioned is for DS3 (T3) connections.
Once you get that information, you can purchase the 'right' module, not necessarily the 'better' module as the 3 modules serve a different purpose :)
__
Edison.
