freeradius.net and Dynamic VLAN Assignment
tonynsx
Is it possible to do dynamic VLAN assignment on Cisco 3560 switches so that when a user logs in, it will prompt for a login, and according to their credentials, their device will be part of a network?
If yes, where would I begin?  I have the freeradius.net installed on a test laptop that I'll be using as the RADIUS server.  I'll be using Windows 7 & 10
balaji.bandi
It is possible and you need to spend some time to explore the solution. Good to start from here,
http://packetlife.net/blog/2008/aug/06/simple-wired-8021x-lab/
BB
thank you, I'll read it
Nice article.  My question is, since I'm using Windows 10 I don't have a MD5-Challenge.  Can I choose one of the other options? I'm going to make a Cisco switch dynamic vlan.
sushanth.shetty
It's completely doable. I've done this at my last job on a 3650 switch using RADIUS server on Windows Server 2012 R2. If you are already using Active Directory in your environment it's super easy to use Windows server for RADIUS authentication.
