Bookmark
Subscribe
952
NAT with secondary IP
Hello guys!
I have some troubles doing NAT. If I set up NAT for a particular port, the server replies, but it does so from a different IP address, (specifically from the main IP).
If I set up NAT to B.B.B.B, the NAT inside works, but replies from A.A.A.A.
What you think that it is due?
/***** THIS IS MY CONFIGURATION ** \
interface GigabitEthernet0/0
 description $ETH-WAN$
 ip address A.A.A.A 255.255.255.0
 ip address B.B.B.B 255.255.255.0 secondary
 ip access-group ACL_IN in
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
 crypto map SDM_CMAP_1
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/0 overload
ip nat inside source static udp 192.168.10.70 5060 B.B.B.B 5060 route-map NONAT extendable
ip nat inside source static tcp 192.168.10.70 22 B.B.B.B 22 route-map NONAT extendable
ip route 0.0.0.0 0.0.0.0 C.C.C.C
ip access-list extended ACL_IN
route-map NONAT permit 11
 match ip address 115
sushanth.shetty
What is your network topology? Are you trying to reach the server from another site or internet?
Secondary IP address command on the router is used to bind another(second) subnet to the same interface.  Ex: On a multi-home setup or during migration from on address scheme to another (say 192.168.1.0/24 to 10.10.1.0/24)
Is this a multi-home setup?
