Showing results forĀ
Search instead forĀ
Did you mean:Ā
FRELAY Issue
eduardopozo56
Hello, guys, im having some problems setting up frame relay for my ccna4 practique, i have done it before and it worked like  a charm but for some reason, it just doesnt want to work anymore.
I have tried to set up in GNS3 and on real time laboratory and it doesnt work correctly, it is a simple Network, a Frame Relay switch with 3 routers connected with point to point links, here are the commands that i used on the frame relay switch/routers:
//***Frame Relay**//
frame-relay switching
interface serial0/0
     encapsulation frame-relay
     frame-relay intf-type dce
     clock rate 64000
     frame-relay route 201 interface serial0/1 102
     frame-relay route 301 interface serial0/2 103
     no shutdown
interface serial0/1
     clock rate 64000
     frame-relay route 102 interface serial0/0 201
     no shutdown
interface serial0/2
     clock rate 64000
     frame-relay route 103 interface serial0/0 301
     no shutdown
**************/// Routers ///**********
Interface serial0/0
     no shutdown
interface serial0/0.102 point-to-point
     bandwith 1024
     frame-relay interface-dlci 102
     ip address 192.168.0.1 255.255.255.252
I wont post the rest of the routers config because they are the same commands (Changing DLCIS and IP ADDRESS)
The problem is that DLCI 102-201 Goes up and i can ping perfectly, DLCI 301 goes up but DLCI 103 never goes up, the interface keeps flapping, i have been breaking my head with this one beacuse i am using the Exact same commands on all the interfaces and 2 ones go up but the third one never goes up.. so????
Richard Burts
You have a typo in your config under serial0/0:
frame-relay route 301 interface serial0/2 301
change it to
it should work much better.
Rick
Rick
Yes, it was a typo at the momment of writing in the forums, it is correct on the Configuration, ty for marking that
As a best practise, do configure
no frame-relay inverse-arp
frame-relay lmi-type ansi/cisco
Sunil
Regards, Sunil Khanna
