FTD eBGP default route into OSPF
Support ACME
Dear ALL,
I'm setting up the the two tier firewall architecture( internet facing firewall is fortinet and the second tier firewall is cisco FTD), i received the default route  0.0.0.0 0.0.0.0 from fortinet firewall via eBGP(fortinet(ASN:64520) and cisco(ASN:64450) is using EBGP connection), I had created the route-map in OSPF redistribution for default route, but i can't receive it from the internal switch.
Anyone can help?
Network Diagram
Fortinet(ASN:64520)->eBGP<-Cisco FTD(ASN:64450)->OSPF<-Cisco C3750E
Thanks.
Support
Hello
The fortinet has no bearing on using the ospf default originate within the ospf stanza
fortinet to asa  = bgp
asa to switch = ospf
So the default originate should work providing the default route from bgp is in the asa rib table
Note: using the
always
keyword will bypass this condition
Kind Regards
Paul
16 Replies 16
Hello
instead of redistributing the received ebgp default advertise it into ospf withdefault originate
Kind Regards
Paul
i can't use the
default originate (default-information originate)
it is because the fortinet no announce the 0.0.0.0 0.0.0.0 , the routing default routing will learn the other site via OSPF.
Jon Marshall
Try redistributing without the route map to narrow down where the problem is.
Jon
i had removed the
 route-map
but still can't learn the default route.
Just to confirm -
you are definitely receiving the default route from the Fortinet and it is in the routing table on the ASA ?
on the switch it is not in the routing table, but is it in the OSPF database ?
Jon
ACME: Yes, i can see the default route on the FTD routing table.
ACME: Yes, only the default routing not in the routing table, other prefix is received.
Sorry that last bit -
so the switch is receiving the default route but it is only in the OSPF database ?
other prefixes are received, is that prefixes redistributed from BGP on the ASA ?
Jon
ACME: May i know how to check it?
ACME: Yes.
please help to check the screenshot
In your original post you said the Fortinet was receiving the default route via EBGP and that the ASA was running EBGP as well.
When Paul suggested using
in OSPF you said you couldn't because the Fortinet was not announcing the default route.
So is the ASA receiving the default route from the Fortinet or not ?
If it is then use
as Paul suggested and if it isn't can you explain what the BGP configuration is for ?
Jon
ACME: The fortinet is generate the default routing to the ASA, if the fortinet found the internet down, it will not generate the default route to ASA.
ACME: Yes.
If it is then use
ACME: i cant use the
it is because i have two site, if the site A internet down , the default route are learn from site B via the OSPF. If I use the
it will get the looping issue.
If you use
and the default route from Fortinet stops being received then the default route is no longer advertised into OSPF.
It would only keep being advertised if you used the
always
keyword in the command.
Would this not work for you ?
Jon
Hello
Note: using the
always
Kind Regards
Paul
it seems work, i 'm doing the verification.
thanks  paul
