Dual ISP Link failover in two different ISR 4431 router
kajale.ankush48
Hello All,
I have 01 ISR 4431 router in that 2 ISP link (MPLS-BGP) terminated and 01 LAN interface is configured with HSRP.
Now, client required router level redundancy. In which we have to terminate on link on one ISR router and other link in second ISR router with failover.
So, kindly suggest what configuration changes i have to do in new router as well as old router.
balaji.bandi
There is thread already have suggested some config (i do not like to re-invent the wheel here)
https://community.cisco.com/t5/routing/load-balancing-and-failover-for-isp-links/td-p/4037409
not sure you running BGP here with ISP ?
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html
BB
not sure you running BGP here with ISP ?  Yes we are running the BGP with ISP.
Then look at the example of next URL it has some steps to follow.
BB
