Full bridge mode WAN with GigabitEthernet interface?
jbrown129
Can the WAN interface be bridged with a LAN port? I've already got a router on my network and I want to use the C1117 just for it's VDSL interface. With the old Cisco 877 I used a bridge group on the ATM0 interface and BVI but it seems that's not supported on IOS-XE.
I would like to be able to bridge my VDSL WAN with GigabitEthernet0/1/0, so that any device I plug in to GigabitEthernet0/1/0 gets the single global WAN IP from my ISP
I thought maybe it was possible to do something with Ethernet0/2/0 which is created as some kind of virtual interface for ATM0/2/0 (apparently you can't bridge ATM interfaces. My config so far:
I'd appreciate a reply, i posted another thread but got nothing.
! Last configuration change at 18:18:54 UTC Tue Sep 13 2022 by admin
version 17.6
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 50000
hostname cisco.rt2
boot-start-marker
boot system bootflash:c1100-universalk9.17.06.03a.SPA.bin
boot-end-marker
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
ip options drop
ip name-server {{ censored }}
ip domain name home.arpa
ip dhcp excluded-address 192.168.1.0 192.168.1.4
ip dhcp pool dhcp-1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
ip dhcp pool opnsense
host 192.168.1.2 255.255.255.0
hardware-address {{ censored }}
dns-server {{ censored }}
login on-success log
ipv6 icmp error-interval 50 20
ipv6 unicast-routing
subscriber templating
license udi pid C1117-4P sn {{ censored }}
memory free low-watermark processor 70173
diagnostic bootup level minimal
username admin privilege 15 secret 9 {{ censored }}
redundancy
mode none
controller VDSL 0/2/0
operating mode vdsl2
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
description Management port
ip address 192.168.2.1 255.255.255.0
negotiation auto
no cdp enable
interface GigabitEthernet0/1/0
no cdp enable
interface GigabitEthernet0/1/1
no cdp enable
interface GigabitEthernet0/1/2
no cdp enable
interface GigabitEthernet0/1/3
no cdp enable
interface ATM0/2/0
no ip address
atm oversubscribe factor 2
interface ATM0/2/0.1 point-to-point
interface Ethernet0/2/0
description Internet Interface
ip dhcp client request classless-static-route
ip address dhcp
no ip redirects
no ip proxy-arp
ip nat outside
ip access-group WAN4_IN in
no negotiation auto
ipv6 address dhcp
ipv6 address pd-ipv6 ::1/64
ipv6 address autoconfig default
ipv6 enable
ipv6 dhcp client pd pd-ipv6
ipv6 traffic-filter WAN6_IN in
interface Vlan1
description Local Area Network
ip nat inside
ipv6 address pd-ipv6 ::1:0:0:0:1/64
ipv6 enable
ip virtual-reassembly
no ip http server
no ip http secure-server
ip forward-protocol nd
ip nat inside source list NATACL interface Ethernet0/2/0 overload
ip route 192.168.2.0 255.255.255.0 192.168.2.2
ip route 192.168.30.0 255.255.255.0 192.168.2.2 2
ip route 192.168.31.0 255.255.255.0 192.168.2.2 2
ip ssh version 2
ip scp server enable
ip access-list standard NATACL
10 permit 192.168.1.0 0.0.0.255
ip access-list standard SNMPACL
10 permit 192.168.50.253
20 permit 192.168.50.252
30 deny any
ip access-list standard WAN4_IN
ip access-list extended SSH_ACL
10 permit tcp 192.168.30.0 0.0.0.255 any eq 22
20 permit tcp 192.168.31.0 0.0.0.255 any eq 22
30 permit tcp 192.168.2.0 0.0.0.255 any eq 22
40 deny tcp any any eq 22
snmp-server community public RO SNMPACL
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
access-class SSH_ACL in
privilege level 15
transport input ssh
line vty 5 14
privilege level 15
transport input ssh
end
16 Replies 16
YES! it works. I feel stupid for not noticing that honestly, I should have. I knew it was close to working!
This is the complete config:
! Last configuration change at 15:55:39 UTC Sun Sep 18 2022 by admin
version 17.6
service call-home
hostname cisco.bsmt-rt2
boot-start-marker
boot-end-marker
aaa new-model
ip options drop
ip dhcp pool dhcp-1
redundancy
mode none
no ip address
negotiation auto
no cdp enable
service instance 100 ethernet
encapsulation untagged
bridge-domain 100
no cdp enable
no cdp enable
no cdp enable
no cdp enable
interface ATM0/2/0
no ip address
no ip address
no negotiation auto
no cdp enable
bridge-domain 100
interface Vlan1
interface BDI100
no ip address
no ip http server
ip route 192.168.1.0 255.255.255.0 192.168.1.2 2
ip route 192.168.30.0 255.255.255.0 192.168.1.2 2
ip route 192.168.31.0 255.255.255.0 192.168.1.2 2
ip ssh version 2
30 deny any
30 permit tcp 192.168.1.0 0.0.0.255 any eq 22
control-plane
line con 0
stopbits 1
line vty 0 4
privilege level 15
transport input ssh
line vty 5 14
privilege level 15
transport input ssh
end
You are so so welcome any time
