09-24-2008 01:24 AM - edited 03-03-2019 11:40 PM
I installed router 7609 in that we planned for link aggregation.So we bought SPA-200 card that is modem card.Now my isp line ends with modem output of 9 pin g.703 connector(male connector).But SPA card is RJ-45 connector.
Can anybody help me connect this interfaces.Any convertor or cable is there to connect this.
i have one more SPA is modem card so we directly we can terminate right.whether we need modem to inetrconnect isp link to spa card.clarrify this too please.
09-24-2008 06:47 AM
Hello!
You can try this: http://www.pccables.com/01910.htm
Is just an example but you can search on your own.
Good luck!
Cheers,
Calin
09-25-2008 04:59 AM
Usually the other end of 9-pin G.703 cable is an RJ45 plugged to an RJ48C Jack. If this is the case, use a straight-through cable to replace it. One end to SPA RJ45 Port and another end to RJ48C Jack.
If however the TELCO Technician doesn't use an RJ48C Jack, call them to replace the 9-pin G.703 cable.
