Gateway of last resort
The_guroo_2
Level 2
Level 2
guys whats gateway of last resort......i have lil bit understanding that if no match uis found it shd be forwarded to this address.....so in other words......if we point a static route to next hope is it become th egateway of last resort??? secondly we have three command to do that i m confuse that which command we shd use an dwhen and why?? kindly see the commands below
ip default-gateway
ip default-network
and ip route 0.0.0.0 0.0.0.0
thanks for looking
dgahm
Level 8
Level 8
IP default-gateway is used by non-routing devices like layer 2 switches. This is the same as the default gateway for a PC, and is only needed by the management interface.
IP default-network and the static 0/0 are used by routers.
Here is a great doc that explains the difference:
http://www.cisco.com/warp/public/105/default.html
Please rate helpful posts.
Dave
