Getting CRYPTO-4-PKT_REPLAY_ERR replay check failed message
Patrick McHenry
Level 4
Level 4
In dynamips I created a GRE tunnel over a VPN between 2 routers over a simulated Internet connection and it works great. I'm able to create EIGRP neighborships, exchange routes and ping across it all day without losing a ping.
Next, I created a l2TPv3 tunnel across the VPN to have a VLAN existing on both sides. Shortly after sending traffic across the l2TPv3 tunnel, the EIGRP neighborship fails, the tunnel breakes, and I start losing pings. The tunnel will then re-establish and the fail again and again and my pings will fail and succeed for a bit then fail.
Console message:
%CRYPTO-4-PKT_REPLAY_ERR replay check failed
From looking around for work-arounds I've increased the crypto ipsec security-association replay window-size to 1028 and used encryption only on both sides of the VPN but, still the tunnel breaks.
See attached diagram.
Any suggestions?
Thank you, Pat.
Lei Tian
Hi Patrick,
What IP are you using for l2tpv3 tunnel?
HTH,
Lei Tian
Lei,
That's a good question. I'll look tonight when I get home to look at my lab.
paolo bevilacqua
Disable replay check altogether.
