Getting internet from switch but cant ping in network
Hello how's everyone doing. So i am very new to this just started studying about 2 weeks ago. I setup a 2611 router with a 3500xl switch using my comcast router. I'm not sure why but when i plug into the switch my pc gets an ip and connects to the internet but if i try to ping anything from the switch it doesn't work. The switch doesn't even have an ip. Here is the running config for the router. Again super new first time trying to set this up by myself no videos.
Thanks in advance for any and all help.
ip subnet-zero
ip dhcp pool labuser
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
dns-server 8.8.8.8
mpls ldp logging neighbor-changes
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface Ethernet0/0
ip address dhcp
ip nat outside
half-duplex
interface Ethernet0/1
ip address 10.1.1.1 255.255.255.0
ip nat inside
half-duplex
ip nat inside source list 1 interface Ethernet0/0 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.1
access-list 1 permit any
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
end
your equipment is extremely old, but I guess that is obvious.
Your switch needs an IP address and a default gateway. Configure the below on the switch:
interface Vlan 1
ip address 10.1.1.2 255.255.255.0
ip default-gateway 10.1.1.1
On the router, make the changes/additions marked in bold:
ip subnet-zero
--> ip dhcp excluded-address 10.1.1.1
dns-server 8.8.8.8
ip address dhcp
ip nat outside
half-duplex
ip nat inside
half-duplex
no ip http server
ip classless
--> access-list 1 permit 10.1.1.0 0.0.0.255
call rsvp-sync
line con 0
line aux 0
line vty 0 4
end
5 Replies 5
interface Vlan 1
ip subnet-zero
dns-server 8.8.8.8
ip address dhcp
ip nat outside
half-duplex
ip nat inside
half-duplex
no ip http server
ip classless
call rsvp-sync
line con 0
line aux 0
line vty 0 4
end
lol yes pretty darn old. someone i know give me a whole bunch of stuff servers routers switches. I think the newest thing in there was a cisco asa 5505 which is still fairly old. I'll try these and report back. Thanks
Worked like a charm thanks again
Hello
Change the routers interface to be duplex full and default route
no ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip route 0.0.0.0 0.0.0.0 eth0/0 dhcp
Check your client pc to make sure it’s obtaining the correct ip addressing- ipconfig/all
Please note - The switch doesn’t require any ip addressing or  default gateway for your host connected to it to work - adding that to the switch would just be for the remote management of the switch- the addressing has no bearing on routing from client to router
Kind Regards
Paul
ahhh i see so that's why it can connect to the internet and lease an ip. Thanks a ton. I just got home so ill give both a shot
