GLBP not load sharing. OSPF is enabled
chris
I have GLBP running on 2 point-to-point T1s with a total of 4 routers, 2 on each end. It appears OSPF is not allowing the GLBP to load share because all traffic is going over 1 connection. How do you configure the routers to load share with OSPF enabled?
chris
Problem is resolved. It was an OSPF area problem. One serial interface was not in the OSPF area.
FWIW, GLBP allows hosts on a LAN to load balance outbound between 2 default gateway routers. GLBP has no influence on routing protocol load balancing over serial links.
