global tunnel in vrf ???
rabeder
hello,
is it possible to configure a tunnel, which has the source and destinationinterface in a vrf AND this tunnel should be a global interface.
with this scenario a want to define a backup pe-pe connection.
6 Replies 6
Harold Ritter
This can be achieved with the tunnel interface command "tunnel vrf". This command forces the lookup of the tunnel source and destination addresses in the configured VRF.
For more information on this command, see the following document:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tir_r/int_t1ht.htm#wp1162526
Hope this helps,
hi hritter,
thx for answer.
yes, i know this command - but in every example i read, the tunnel itself is in a vrf.
i want the tunnel (which has source and destination in a vrf) to be a global interface, where i can configure label-switching for example.
i want to use a vrf interface on a pe for backuping the global pe-pe interface.
i know - its a littlebit strange - but i want to try.
The tunnel interface itself will be part of the global unless you specifically configure it to be part of a VRF using the command "ip vrf forwarding ".
Hope this helps,
hi,
thanks - even one question:
i have a vxr 7206 - the command is not available.
is this a spezial ios ??
mplsrbgope01(config-if)#tunnel ?
checksum enable end to end checksumming of packets
destination destination of tunnel
flow flow options
key security or selector key
mode tunnel encapsulation method
mpls MPLS tunnel commands
path-mtu-discovery Enable Path MTU Discovery on tunnel
sequence-datagrams drop datagrams arriving out of order
source source of tunnel packets
tos set type of service byte
tsp-hop Define a TSP hop
ttl set time to live
udlr associate tunnel with unidirectional interface
mplsrbgope01(config-if)#tunnel vrf ?
% Unrecognized command
mplsrbgope01(config-if)#tunnel vrfmplsrbgope01(config-if)#tunnel ?
flow flow options
What level of code are you running? This feature as been integrated in 12.3T.
Hope this helps,
hi hritter,
i use
System image file is "disk2:c7200-js-mz.123-12a.bin"
so i have to upgrade to 12.3T or i think its better to use 12.4
thanks
