GRE between router and ASA
ubuntu_guy
I have an 1841 at a remote site that terminates its ipsec vpn to an asa5510. I want to create a GRE tunnel to I perform the following on the router;
conf t
int tunnel 5
tunnel source f0/0
tunnel-destination x.x.x.x
and that brings up the tunnel on the router/remote side.
My question is towards the syntax of creating the other end of the tunnel, the ASA does not allow;
conf t
int tunnel 5
How do I create the tunnel interface and once it's created are the rest of the tunnel configuration commands the same as on the routers?
Thanks.
cadet alain
I don't think the ASA can terminate a GRE tunnel.
Regards.
Alain.
cadet alain
Regards.
Alain.
well that blows... any ideas on where I'd terminate GRE tunnels at if my VPN terminations are all on that ASA?
Thanks for the info, I had no idea.
