QoS help needed
cisconoobie
Level 2
Level 2
I am trying to allocate atleast 512Kbps to HREAP traffic but for some reason I get drops on my class-map cl_HREAP while class-default has no drops. I have a T1 and the link is barely used so I don't know why its dropping traffic? Does it think its a 64k link? Please verify my config.
access-list 150 permit udp any any eq 12223
access-list 150 permit udp any any eq 5247
access-list 150 permit udp any eq 12223 any
access-list 150 permit udp any eq 5247 any
class-map match-all cl_HREAP
match access-group 150
policy-map pm_HREAP
class cl_HREAP
  bandwidth 512
class class-default
  fair-queue
interface ATM1/0
bandwidth 45000
no ip address
ip pim sparse-mode
load-interval 30
atm scrambling cell-payload
atm uni-version 3.0
no atm ilmi-keepalive
interface ATM1/0.6 point-to-point
bandwidth 1544
ip address 10.1.1.1 255.255.255.252
ip pim sparse-mode
ip policy route-map INTERNET_OUT
pvc 6/36
  protocol ip 10.1.1.2 broadcast
  vbr-nrt 1500 1500 1
  encapsulation aal5snap
  service-policy output pm_HREAP
Here are my findings, please advise.
3845#show policy-map interface atm1/0.6
ATM1/0.6: VC 6/36 -
  Service-policy output: pm_HREAP
    Class-map: cl_HREAP (match-all)
      10480 packets, 1539855 bytes
      30 second offered rate 17000 bps, drop rate 0 bps
      Match: access-group 150
      Queueing
        Output Queue: Conversation 73
        Bandwidth 512 (kbps) Max Threshold 64 (packets)
        (pkts matched/bytes matched) 7455/1077130
        (depth/total drops/no-buffer drops) 0/745/0
    Class-map: class-default (match-any)
      13291 packets, 1474327 bytes
      30 second offered rate 9000 bps, drop rate 0 bps
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 64
        (total queued/total drops/no-buffer drops) 0/0/0
cisconoobie
Level 2
Level 2
If I do show queuing, I see that I'm using 630 Kilobits of available bandwidth, this may be the issue but where do I mention to use 1500 or atleast 1100 Kbps being 75% of that? Where is it getting this 630 Kbps calculation?
3845#show queueing interface atm1/0.6
  Interface ATM1/0.6 VC 6/36
  Queueing strategy: weighted fair
  Output queue: 26/512/64/52507 (size/max total/threshold/drops)
     Conversations  1/41/64 (active/max active/max total)
     Reserved Conversations 1/1 (allocated/max allocated)
     Available Bandwidth 630 kilobits/sec
If you are getting drops, it is an indication that 512 guaranteed bandwidth is not enough. You need to allowed more for that class-map.
As your other question, it defaults to 75% available bandwidth but this can be modified with the max-reserved-bandwidth command.
Please refer to the documentation:
http://www.cisco.com/en/US/tech/tk39/tk48/technologies_tech_note09186a00800fe2c1.shtml
Edison
