GRE over BGP
arunkumarravi
I have 3 routers R1, R2, R3 connected within same AS (IBGP).
I would like to establish a GRE tunnel between R1 and R3, can someone share me some guide please.
2 Accepted Solutions
R1-R2-R3
in R1
ip route 0.0.0.0 0.0.0.0 <R1-R2 link IP>
router bgp 100
neighbor <R3 tunnel IP>  remote-as 100
network LAN <<< LAN you want to pass through tunnel
in R3
ip route 0.0.0.0 0.0.0.0 <R3-R2 link IP>
router bgp 100
neighbor <R1 tunnel IP>  remote-as 100
do this step
and finally share
show ip bgp
I will check
The original poster asks "may I know what was the reason behind this". The answer is that in the earlier implementation the tunnel existed, but there was no routing logic that used the tunnel. When you change BGP to use the tunnel addresses then there is routing logic that uses the tunnel.
Rick
11 Replies 11
balaji.bandi
what is the use case here, why you like to have GRE tunnel when there is already connection (GRE tunnel not a secure tunnel)
Also  you need explain the config, if you using same interface IP where iBGP running, that may break your iBGP peering (just in case)
basic GRE tunnel config can be find here :
https://community.cisco.com/t5/networking-knowledge-base/how-to-configure-a-gre-tunnel/ta-p/3131970
BB
HI Balaji.
Yeah I understand that GRE will just encapsulate the header and no encryption but I am curious to know if we can use BGP route instead of static.
Consider the below topology:
192.168.1.0 >>(etho) R1(eth1) >>>>(eth0) r2 (eth1)>>>(eth0) r3 (eth1) >>> 192.168.2.0
R1 config.
Tunnel IP is 1.1.1.1 and INterface ip is 4.1.1.1 (eth1).
r1 and r2 are neighbors(BGP) , R1 belongs to AS 2 and R2 Belongs to AS 3
R2 config:
Eth0 Ip is 4.1.1.2 and eth1 IP is 5.1.1.1
R2 Belongs to AS 3.
R3 config.
Eth0 ip is 5.1.1.2 and Eth1 Ip is 192.168.2.1.
Tunnel Ip is 2.2.2.2.
AS of r3 is 3 and it is neighbor to r2.
This my config.
And instead of BGP if I have static route then  I need to create a static route on R1 and R2 with Remote tunnel Ip as next hop.
So it is possible to SEND the traffic via GRE tunnel with the help of static route?
--> I have 3 routers R1, R2, R3 connected within same AS (IBGP)
--> r1 and r2 are neighbors(BGP) , R1 belongs to AS 2 and R2 Belongs to AS 3
Post the full running configurations of all three routers so we can lab this up.
R1-R2-R3
in R1
router bgp 100
in R3
router bgp 100
do this step
and finally share
show ip bgp
I will check
arunkumarravi
R1 config.
interface Tunnel10
ip address 1.1.1.1 255.255.255.0
ip mtu 1400
tunnel source 4.1.1.1
tunnel destination 5.1.1.2
interface Ethernet0/0
interface Ethernet0/1
ip address 4.1.1.1 255.255.255.0
router bgp 2
bgp log-neighbor-changes
network 192.168.1.0
neighbor 4.1.1.2 remote-as 2
ip route 0.0.0.0 0.0.0.0 4.1.1.2
SH IP BGP output:
Network Next Hop Metric LocPrf Weight Path
*> 192.168.1.0 0.0.0.0 0 32768 i
*>i 192.168.2.0 4.1.1.2 0 100 0 3 i
R2 router:
 ip address 4.1.1.2 255.255.255.0
 ip address 5.1.1.1 255.255.255.0
router bgp 2
 neighbor 4.1.1.1 remote-as 2
 neighbor 4.1.1.1 next-hop-self
 neighbor 5.1.1.2 remote-as 3
 neighbor 5.1.1.2 next-hop-self
SH IP BGP:
*>i 192.168.1.0 4.1.1.1 0 100 0 i
*> 192.168.2.0 5.1.1.2 0 0 3 i
R3 router:
interface Tunnel10
 ip address 2.2.2.2 255.255.255.0
 ip mtu 1400
 tunnel source 5.1.1.2
 tunnel destination 4.1.1.1
 ip address 192.168.2.1 255.255.255.0
 ip address 5.1.1.2 255.255.255.0
router bgp 3
 network 192.168.2.0
 neighbor 5.1.1.1 remote-as 2
ip route 0.0.0.0 0.0.0.0 5.1.1.1
SH IP BGP:
*> 192.168.1.0 5.1.1.1 0 2 i
*> 192.168.2.0 0.0.0.0 0 32768 i
that OK but why you config BGP in R2 ?
why you use no same subnet for tunnel IP , I see 1.1.1.1 and 2.2.2.2, it work but I prefer use same subnet.
I have changed the subnet now(1.1.1.1/24 and 1.1.1.2/24).
that OK but why you config BGP in R2 ? >>> but without BGP how the neighbour will be formed?
Would you want me to configure static route in r2?
The problem is Tunnel is UP and I am able to ping however the traffic is not encapsulated.
is it because of nexthop?
Ohh man, it worked
As per your instruction I configured this.
After. this I could see the traffic is encapsulated, may I know what was the reason behind this?
first
use 1.1.1.1 and 1.1.1.2
show ip route
then
use 1.1.1.1 and 2.2.2.2
show ip route
SHARE HERE
Rick
I am glad that our suggestions have been helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
