GRE tunnel behind Nat
jfeo
I am trying to setup a GRE tunnel behind a service providers router    CiscoRouter3900 >ATT DSL Router > INTERNET > Headend CiscoRouter 3900
port 47 is open on the ATT DSL router but I can still getttin up/down status
13 Replies 13
post the configurations of both routers. Is this GRE only ? Otherwise you might need UDP 500 and/or TCP 1723 as well...
yes GRE only. I can ping wan ip address from either sites
Head end
interface Tunnel1
description TEST_IPICS
ip address 10.10.1.1 255.255.255.252
ip pim sparse-mode
keepalive 3 2
tunnel source GigabitEthernet0/1
tunnel destination xx.xx.xx.xx
tunnel path-mtu-discovery
end
Remote site
interface Tunnel1
ip address 10.10.1.2 255.255.255.252
ip pim sparse-mode
keepalive 3 2
tunnel source GigabitEthernet0/0
end
try the below (additions in bold)
Head End
interface Tunnel1
ip mtu 1400
tunnel mode gre ip
ip pim sparse-mode
keepalive 3 2
end
Remote site
interface Tunnel1
ip mtu 1400
tunnel mode gre ip
ip pim sparse-mode
keepalive 3 2
end
Added no change. I had this working when remote site wasn't behind a NAT.
Port forwarding only on 47
which traffic is being translated ? Post the full configs of both sites...
The Headend is directly connected to the ISP. The Remote site is behind a router giving out a DHCP address.
both configs are standard. Basically it would be like if you put a Cisco router behind your linksys router and tried to establish a GRE tunnel
interface Tunnel1
description IPICS
ip mtu 1400
ip pim sparse-mode
keepalive 3 2
cdp enable
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
duplex auto
speed auto
ip route 10.10.10.10 255.255.255.255 Tunnel1
ip route 192.168.1.0 255.255.255.0 Tunnel1
ip route 0.0.0.0 0.0.0.0 dhcp
you need to put the ATT DSL router in bridge mode for this to work. What is the IP address assigned to GigabitEthernet0/0 ?
it gets a dhcp 192.168.0.xxx gateway 192.168.0.254.
I have port 47 port forward to 192.168.0.xxx
that is the problem. Your tunnel source is now a private IP address, while on the other side, it is a public address, that is why the tunnel won't come up. Is it an option to put the modem/DSL router in bridge mode ?
What type/brand is the ATT DSL router ?
Or, actually, what is the purpose of the ATT DSL router as an addition to your existing network ?
Basically I am trying setup a GRE tunnel from my house while still using my existing network.
It is a att NVG599
Ok, that makes sense. The NVG599 has a coax connector right ? So you cannot simply hook up your Cisco...
Putting the NVG599 in bridge/passthrough mode is fairly easy. That way, your Cisco will work with the tunnel as your originally configured it.
Have a look here for instructions:
http://www.dslreports.com/faq/17734
a.alekseev
Level 7
Level 7
GRE do not use port 47.
47 is a protocol number.
as workaround you can try IPSec (VTI) instead of GRE.
