Dual DMVPN with ASA
Hello
I have to install 2 ASA Firewalls in a dual DMVPN Router system.
Is it better to install them behind or in front of the router?
Where do i find some information ?
As always: It depends ...
Do you want to protect the routers? Then install the firewalls in front of the routers. Do you want to filter on the user-traffic that leaves the tunnel? Then install them behind the routers. You could also do both by placing the routers inside a DMZ, but that makes the routing-config more difficult.
It would be nice if i can see the traffic from the VPN´s and the routers protected.
So do you know where i can find some information about the Router inside a DMZ?
This design guide might help: http://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Aug2014/CVD-VPNWANDesignGuide-AUG14.pdf
Thanks i will read this document
best regards
