GRE tunnel IOX XR, IPs not reachable
I am trying to make a GRE tunnel in a vrf on IOS-XR.
I am able to make the tunnel interface up, but I am not getting the local IPs assigned to the Tunnel interface being shown in the vrf table. My final aim is to form BGP with the local IPs assigned (/30 in my case) to the tunnel interface.
Config:
RP/0/RSP0/CPU0:Test# sh run int tunnel-ip45
interface tunnel-ip45
 vrf Test
 ipv4 address 109.39.214.217 255.255.255.252
 tunnel mode gre ipv4
 tunnel source Loopback779
 keepalive 10
 tunnel vrf Test
 tunnel destination 109.39.218.10
RP/0/RSP0/CPU0:Test#sh int tunnel-ip 45
Fri Oct 18 18:26:50.359 CET
tunnel-ip45 is up, line protocol is up
RP/0/RSP0/CPU0:Test#ping vrf Test 109.39.214.217
Fri Oct 18 18:31:31.119 CET
Sending 5, 100-byte ICMP Echos to 109.39.214.217, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
RP/0/RSP0/CPU0:Test#sh route vrf Test 109.39.214.21
Fri Oct 18 18:52:16.540 CET
% Network not in table
Jaideep Choudhary
Harold Ritter
Hi Jaideep,
What platform are you testing this on?
Hi Harold,
The Platform is ASR 9K  with 6.3.3 IOS XR.
Jaideep Choudhary
The show command is incorrect.
Could you post the output for the correct command:
sh route vrf Test 109.39.214.217
Should the tunnel destination be reachable via the vrf or the global?
