GRE TUNNEL Question
NC16390371
We have a point to point GRE tunnel which has some issues that I would like to see if I can get some guidance.  When clients connect to the WLAN and are routed thru this tunnel they experience latency on some https applications.  However if you change the MTU on the  laptops 802.11 radio from 1500 over to 1476 the problem disappears.  What is the best approach to change this without changing it on every machine.
Traffic Flow is as follows:
Client --> LWAPP --> (TUNNELED) --> WLAN Controller --> VLAN INTERFACE --> TUNNEL <<WAN>> TUNNEL --> <<INTERNET>>
10 Replies 10
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If your WLCs support it, enable mss adjust, globally.
If your WAN GRE tunnels support it, set IP MTU to 1476, mss adjust to 1436 and enable tunnel PMTUD.
The bytes added by GRE result in a frame that sometimes is larger than the permitted MTU. I have found that frequently using the command ip tcp adjust-mss is an effective way to avoid the problem of fragmenting traffic that is going through GRE. I generally apply it on the LAN interface but I have seen some people apply it on the tunnel interface.
Rick
Rick
Hello
In regards to Joesph and Richard comments
int tun xx
ip mtu 1476
ip tcp adjust-mss 1436
res
Paul
Kind Regards
Paul
Disclaimer
Posting
And to add to Paul's actual tunnel interface configuration statements . . .
tunnel path-mtu-discovery
One last question.... can I do the following :
interface vlan xxx
ip mtu 1476
interface tunnel xx
I would rather change it on the VLAN interface before it hits the tunnel.
Disclaimer
Posting
You might be able to do that, but for different reasons, you want to apply to the tunnel interfaces.
Regarding your question about whether needed on both ends, MTU and PMUD yes, adjust-mss actually no, but normally you place it on both ends too.  (Adjust-mss applies to traffic in both directions.)
hello
i would apply it on the tunnel if thats where your traffic is traversing
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Can I assume we need these on both ends of the tunnel ?
hello
yes apply both ends
res
paul
Kind Regards
Paul
@ Joseph
wasnt aware of that -
cheers
paul
Kind Regards
Paul
