Cisco 1841 - Routing Between Ethernet Ports
coconut_munkey
I have a Cisco 1841 that has an ADSL (ATM) card installed.  It was previously used with an ADSL line to provide NAT routing for an office.  Now I want to use it witha cable modem, which would mean abandoning the ADSL interface and instead routing between the two Ethernet ports.
Between the Cisco and the LAN is a Linux transparent proxy.  It provides routing between 192.168.1.0 (LAN) and 192.168.2.111 (Cisco LAN interface).
The network looks like this:
Cable Modem(174.76.21.1)(gateway) --- (174.76.21.10)(WAN) Cisco 1841 (LAN)(192.168.2.111) --- (192.168.2.11) Linux Proxy (192.168.1.10) --- (192.168.1.0) LAN
For testing and diagnostics, I've connected a laptop to each FastEthernet port on the router.  One laptop is configured with the IP 174.76.21.1 to simulate the cable modem gateway and the other laptop has the IP 192.168.2.11 to simulate the Linux proxy.  From those systems I've performed the following diagnostics with the following results:
From 192.168.2.11
Ping 192.168.2.111 - OK
Ping 174.76.21.15 - OK
Ping 174.76.21.1 - Timed out
From 174.76.21.1
NAT translation to LAN IP's failing
There are some vestiges of the ADSL configuration, but I've cleaned most of it out and shut down the ATM interfaces.  Here's my config:
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip name-server 209.244.0.3
ip name-server 209.244.0.4
bridge irb
interface FastEthernet0/0
description LAN0$FW_INSIDE$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ETH-LAN$
ip address 192.168.2.111 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description WAN$ETH-WAN$
ip address 174.76.21.10 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
shutdown
interface ATM0/0/0.2 point-to-point
shutdown
pvc 0/35
  pppoe-client dial-pool-number 1
interface BVI1
mtu 1492
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 174.76.21.1
ip route 192.168.1.0 255.255.255.0 192.168.2.11
ip http server
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source list 2 interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.1.13 1723 interface FastEthernet0/1 1723
ip nat inside source static tcp 192.168.1.14 6004 interface FastEthernet0/1 6004
ip access-list extended sdm_bvi1_out
remark SDM_ACL Category=1
permit ip any any
ip access-list extended sdm_dialer0_out
permit ip any any
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line aux 0
line vty 0 4
login
end
Where am I going wrong?
5 Replies 5
enkli
As you have traffic fro 1.0 you do not need the nat for 2.0
Sent from Cisco Technical Support Android App
Okay.  But the .1.0 LAN is still not getting out to the internet.  It can see as far as the WAN Ethernet interface, but no further.  It seems like the router isn't forwarding to the final hop - the ISP's gateway.
try to connect directly to interface f0/0 and take an IP from the 192.168.2.0/24 range, if you get internet connection then it might be an issue with the linux box
after that connect behind the linux proxy and take an IP from the 192.168.1.0/24 range and do a traceroute and provide the output of show ip nat translation
Thank you for the suggestion, Ahmad.  I am currently doing as you suggest - testing with a system hooked directly to f0/0 with a 2.x address and the Linux proxy removed from the picture.  The system with the 2.x address is unable to get any further than the f0/1 interface on the router.
Can you provide the output of show ip nat translation
