Hardening configuration on a switch - vty and tty lines
Nissi
Doing a show line? on my switch produced the following output:
switch# sh line ?
  <0-16>   First Line range
  console  Primary terminal line
  summary  Quick line status summary
  vty      Virtual terminal
  |        Output modifiers
  <cr>
Does this imply that tty lines do not exist on the switch?
My second question is, if I should only define line vty 0 4 with the appropriate parameters, can unauthorized access be gained to the switch from vty 5 15 although they are not defined?
3 Accepted Solutions
vty 0-4 mean only 5 simultaneous connections (6th user not allowed)
high level for reference: -  ( deep dive google is your help)
TTY is Physical Port
VTY is Virtual port
BB
'vty 0 4' and 'vty 5 15' do not correspond to physical connections. They are basically just 'placeholders' for virtual connections, without any hardware being actually associated with them. So, vty 0 4' means only that 5 virtual connections are possible. When you connect to the device (router or switch) you cannot actually specify the VTY line number. If 'vty 5 15' lines do not exist, nobody can connect to these virtual lines either.
That as opposed to TTY lines, these are asynchronous lines, used for inbound or outbound modem and terminal connections, with actual hardware support. I remember these from e.g. Cisco 2509 (very old) access server, and routers used as terminal servers. TTY lines can only be found on routers, not on switches.
Hello
If you left the all other vty alone then no access would be allowed however I tend to secure those also in conjunction with AAA local credentials, ssh, acl and timeouts.
See attached for example:
Kind Regards
Paul
9 Replies 9
balaji.bandi
the show is normal output.
Line con  - is the console, if someone access console port physically able to get access so you need to secure this with password or AAA configuration
vty 0-15 (how many VTY lines you need open, more open is more issues, in standard Vty 0-4 is configured so only Limited users can Login
this also required to tighten the security for the user to login using SSH ( try to avoid telnet - not advise here)
Follow switch hardening guide :
https://www.cisco.com/c/en/us/support/docs/ip/access-lists/13608-21.html
BB
Thanks for responding. I've taken care of the Line con already and I've defined acceptable parameters for vty 0 4. What I'm interested in knowing is if nothing is defined for vty 5 15, can those lines be accessed by unauthorized means?
To clarify the question regarding line tty. Does this exist on a switch or only on routers?
VTY is Virtual port
BB
Thanks Georg. Spot on. This is what I was looking for regarding the TTY lines.
Hello
@Georg Pauwen @wrote: When you connect to the device (router or switch) you cannot actually specify the VTY line number.
This is not necessary true you can connect to a specific vty line if you desire you just to need to configure that line to do so
Kind Regards
Paul
@paul driver
How ? Without the SSH client knowing the specific line number ? That is what I meant...
Hello
The below will allow ssh to a specific vty line
Example:
rtr - 1.1.1.1.
line vty 24
rotary 127
remote rtr
ssh -l stan 1.1.1.1 3127
Kind Regards
Paul
Hello
Kind Regards
Paul
