Packet Tracer exercise help needed.
bytor4510
Hi, I'm doing a packet tracer exercise for my ccna at uni. Here's the running config,
Router#show run
Building configuration...
Current configuration : 1269 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface Tunnel1
ip address 192.168.0.1 255.255.255.0
mtu 1476
tunnel source GigabitEthernet0/0/0
tunnel destination 99.0.0.38
interface GigabitEthernet0/0/0
ip address 99.0.0.33 255.255.255.240
duplex auto
speed auto
interface GigabitEthernet0/0/1
ip address 99.0.0.49 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/2/0
switchport mode access
switchport nonegotiate
interface GigabitEthernet0/2/1
interface GigabitEthernet0/2/2
interface GigabitEthernet0/2/3
interface Vlan1
ip address 99.0.0.4 255.255.255.224
router ospf 100
router-id 10.10.10.10
log-adjacency-changes
network 99.0.0.32 0.0.0.15 area 0
network 99.0.0.48 0.0.0.3 area 100
ip classless
ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/0/0
ip flow-export version 9
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
Router#
There are 9 isr4321 routers, 5 2960 switches, 11 pc's and 1 server and 10 areas. I've set up all the addressing and areas are all working. There's a GRE tunnel that's also working.
Working on R1
Router#show ip int bri
GigabitEthernet0/0/0 99.0.0.33 YES NVRAM up up
GigabitEthernet0/0/1 99.0.0.49 YES NVRAM up up
GigabitEthernet0/2/0 unassigned YES unset up up
GigabitEthernet0/2/1 unassigned YES unset up down
GigabitEthernet0/2/2 unassigned YES unset up down
GigabitEthernet0/2/3 unassigned YES unset up down
Tunnel1 192.168.0.1 YES manual up up
Vlan1 99.0.0.4 YES manual up up
There's a single pc connected to G0/2/0 which can ping all interfaces on R1 but fails to ping any further. I've been stuck on this for about 6 hours, any help would be much appreciated?
12 Replies 12
Martin L
it would be easier to look at  your PT file;  you can attach your PT file here; it must be in a zip format;
Regards, ML
**Please Rate All Helpful Responses **
Yes I know, but I'm a bit reluctant to post it as its an exam paper. I don't want to take the risk.
Thanks for replying
I agree with @Martin L , you need to advertise:
network 99.0.0.0 0.0.0.31 area 0
or
network 99.0.0.0 0.0.0.31 area 100
Martin L
OK, so PC's gateway is 99.0.0.4 and PC can ping it; Can others ping that IP? Looks like network 99.0.0.x /27 is not advertised by OSPF.
Regards, ML
99.0.0.33 is the gateway for the pc, interface 0/0/0 or should it be 0/2/0? I can't give that interface an IP address so should I give the address of the vlan 1?. I can ping every interface on R1 from the pc. No, other devices can't ping 99.0.0.4. we are told the pc can not participate in ospf on interface g0/2/0. That interface is an add-on module, so I'm guessing it's an svi? Not familiar with configuring that type of interface. I've place it in vlan 1
Ok so changing the default gateway on the pc didn't make any difference. Here's OSPF database
Router#show ip ospf da
OSPF Router with ID (10.10.10.10) (Process ID 100)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
5.5.5.5 5.5.5.5 474 0x80000004 0x00a013 1
11.11.11.11 11.11.11.11 479 0x80000003 0x0034b2 1
4.4.4.4 4.4.4.4 479 0x80000003 0x002ef2 1
8.8.8.8 8.8.8.8 479 0x80000003 0x0043b8 1
2.2.2.2 2.2.2.2 524 0x80000002 0x008944 1
7.7.7.7 7.7.7.7 474 0x80000004 0x006b9a 1
6.6.6.6 6.6.6.6 474 0x80000005 0x00bb50 1
3.3.3.3 3.3.3.3 480 0x80000003 0x006cbd 1
10.10.10.10 10.10.10.10 468 0x80000005 0x0036bb 1
Net Link States (Area 0)
99.0.0.38 11.11.11.11 468 0x80000008 0x0058c0
Summary Net Link States (Area 0)
99.0.0.48 10.10.10.10 514 0x80000001 0x00663f
99.0.0.60 5.5.5.5 514 0x80000001 0x008429
99.0.0.76 8.8.8.8 514 0x80000001 0x008908
99.0.0.72 7.7.7.7 519 0x80000001 0x00cfc9
99.0.0.64 11.11.11.11 513 0x80000001 0x00a7e9
99.0.0.56 4.4.4.4 514 0x80000001 0x00caea
99.0.0.52 2.2.2.2 515 0x80000001 0x002f92
99.0.0.68 6.6.6.6 519 0x80000001 0x00168b
99.0.0.0 3.3.3.3 515 0x80000001 0x00729b
Router Link States (Area 100)
10.10.10.10 10.10.10.10 523 0x80000001 0x0072ff 1
Summary Net Link States (Area 100)
99.0.0.32 10.10.10.10 519 0x80000001 0x00be03
99.0.0.76 10.10.10.10 449 0x80000002 0x005532
99.0.0.64 10.10.10.10 449 0x80000003 0x00cbc6
99.0.0.56 10.10.10.10 449 0x80000004 0x001a7f
99.0.0.68 10.10.10.10 449 0x80000005 0x009fec
99.0.0.0 10.10.10.10 449 0x80000006 0x009f4c
Router#
Could it be the way I have g0/2/0 configured? Anywho, this exercise is divided into 4 tasks and worth 20%. This is task 3 (worth 5%), configure a gre tunnel (which I have, and its working I've tested using traceroute) but it says configure the pc's and test connectivity (which I can't, boo!) So if I can't do it I'll lose a couple of %.....**bleep**, I know but it bugs me. ACL next, then that's it. At some point I'll need to call it a day and move on to the other questions on the exam which are essays. I've got until June 3rd, that's not enough time
no, I would make sure that other devices can  ping 99.0.0.4 ok.  focus on that.  try static route on neighboring ospf router to see if you can ping 99.0.0.4
Regards, ML
Please attach partial work or empty PT activity  with instructions for us to look at.
Right, anyone connected to switching module in that router, aka Gig0/2/0, will use SVI interface. so Pings go to interface VLan 1 IP via module internally.   IP on interface Vlan 1 and vlan 1 is ok if access port is in vlan 1. That int vlan 1 is default gateway for any PC connected to access port.
Problem is other devices can't ping 99.0.0.4.  I guess advertise it  via OSPF or add static route on other end router so that other devices can ping 99.0.0.4 OK .
Ping is 2-way process.  Ping to and from must be OK for ping to be OK.  I guess, your return ping does not know how to reach source.
Regards, ML
Thanks for helping.
I've set a static route on r1 "ip route 192.168.1.0 255.255.255.0 g0/0/0" and 0.0.0.0 0.0.0.0 g0/0/0 still not working. g0/0/0 is the interface of my gre tunnel.
it is very tedious to give advice, since we don't really know what you have configured, and how your devices are connected. I would suggest to post the zipped project file, and then delete your post when this has been solved.
