Hardware Failure shown on port in Nexus 5596
Siddharth Jain
Today one of the link of N5k to one of the location went down & following is the description shown in the nexus:
Ethernet1/23 is down (Hardware failure)
Dedicated Interface
  Hardware: 1000/10000 Ethernet, address: 547f.eea8.a5c1 (bia 547f.eea8.a59e)
  Description: Uplink ___
  Internet Address is 10.x.y.z/30
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  auto-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 4d10h
  7 interface resets
  30 seconds input rate 0 bits/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    1188377866 unicast packets  1058370 multicast packets  11 broadcast packets
    1189436247 input packets  409281411065 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    1720716012 unicast packets  1210983 multicast packets  19 broadcast packets
    1721927014 output packets  1472271989010 bytes
    41 jumbo packets
    49 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
Kindly help us in knowing the source of error and solution which can be provided against this issue.
Siddharth Jain
7 Replies 7
Simon Brooks
Show int eth1/23 tran
Sent from Cisco Technical Support Android App
sh int eth 1/23 tra
Ethernet1/23
    transceiver is present
    type is 10Gbase-LR
    name is CISCO-FINISAR
    part number is FTLX1474D3BCL-CS
    revision is A
    serial number is FNS16120QU5
    nominal bitrate is 10300 MBit/sec
    Link length supported for 9/125um fiber is 10 km
    cisco id is --
    cisco extended id number is 4
jawad-mukhtar
Level 4
Level 4
Contact Cisco TAC and arrange for an RMA.  Nothing else you can do.
Jawad
Jawad
InayathUlla Sharieff
Hi Sidhharth,
You need to raise the RMA for the module to get it replaced.
further more you can see that the port might have failed on the module. run the following command:
show diagnostic result module all
regards
Inayath
It shows following result:
    16) TestFabricPort :
   Eth     1   2   3   4   5   6   7   8   9  10  11  12  13  14  15  16  17  18
  19  20
   Port ------------------------------------------------------------------------
   Eth    21  22  23  24  25  26  27  28  29  30  31  32  33  34  35  36  37  38
  39  40
           .   .   F   .   .   .   .   .   .   .   .   .   .   .   .   .   .   .
   Eth    41  42  43  44  45  46  47  48
All the test are passed except the above mentioned
Siddharth
Here you can do one more thing ... You can try to reset module from command
5k# config t
5k-config# poweroff module 1 ( Particular module)
5k-config# no poweroff module 1 ( Particular module)
It will reset the module and it should work.. Because it work for me.
in this case we make a change of port
