Hardware for Multilink PPP?
ksarin123_2
Hi Folks -
I have a Cisco 2821 router that I will be using for terminating multiple T'1 using MPPP. The total number of T1's would be 6. The 2821 already has two vwic2-2mft-t1/e1 cards giving me a total of 4 T1 interfaces.
So if I order WIC-1DSU-T1-V2 (two of them), will those work with the existing VWIC cards I already have to create a MPPP bundle?? Or should I order another vwic2-2mft-t1/e1??
Also, will the 2821 handle 6 T1's??
In addition, is there a better way (may be another network module or HWIC) of terminating the 6 T1's on the 2821??
Thanks for your help!
royalblues
Level 10
Level 10
Though you can terminate 6 links on the 2821, Cisco recommends not more than 4 T1/E1s on a 2821.
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd80169bd6.html
It would be better to upgrade to a 38xx
Narayan
