Bookmark
Subscribe
13355
Has anyone know how to make password recovery for 2900 series routers?
esinyener
I need to do password recovery for a 2911 router. But ı can't find any documentation about it. I can be able to login at the first login, unfortunately ı logged out without changing the password. Now I can not log in and I can not open rommon with the ctrl+break key sequence. ( or any other recommended one)
6 Replies 6
paolo bevilacqua
Please send the full rommon console log at boot.
Thanks for the reply but i have solved the problem in the meanwhile.
Actually i was expecting to see the rommon prompt as in 2800 series. A 2800 router is directly prompting the rommon just after "Readonly ROMMON initialized" sentence is shown. However in 2900 series router you should wait till it finishes decompression of the image file.
Thanks @esinyener
The Procedure its different from the others routers, bacause no wait to load or decompres the IOS to send you to ROMMON,
Thanks Again.
Norman Santana.
The FASTEST way for a 2900 router to go into ROMmon is to power down the router, eject all the CF and power the router back on.
hello sir i got the same problem with you can you send me the solution plzz
Here are the procedures I've used to perform a password recover on 2900 series routers to include the 2911.
http://www.cisco.com/en/US/products/ps5854/products_password_recovery09186a0080b34901.shtml
