help in configuring telnet
sivakondalarao
We have two PIX 515E firewalls working in HA mode.
I wanted to configure telnet access to firewalls from outside interface.
PIX version is 6.3(5)
I kept PC outside to outside interfaces.
PIX outside IP is 10.10.200.3, inside IP is 10.10.202.5 corresponding virtual IPs are 10.10.200.2 and 10.10.202.7
I have tried following configurations:
pix(config)#telnet 0 0 inside
pix(config)#telnet 0 0 outside
pix(config)#telnet 10.10.200.0 255.255.255.0 outside
pix(config)#telnet 10.10.202.0 255.255.255.0 inside
pix(config)#telnet 10.10.200.200 255.255.255.255 outside
I am able to telnet from internal interface side using inside ip address.
But from outside test pc with IP 10.10.200.200 I am not able to telnet to PIX.
I enabled logging console 5.
when I tried to telnet to outside virtual IP it is not showing any traffic to firewall.
If I try to outside interface I am able to see the traffic like
packets received from source 10.10.200.200 to 10.10.200.3
any help in this configuration. I wanted to telnet firewall from test pc.
SKRAO
spremkumar
Level 9
Level 9
Hi Siva
Configure SSH and try out SSH from outside world ,you wont be able to do telnet from outside world.
Telnet is permitted only from the inside network.
regds
Hi Prem,
So I can confirm that telnet is not at all possible from outside world through outside interface to PIX to manage it.
The other option is SSH to connect to the PIX for management purpose.
Thanks for your reply.
SKRAO
mmorris11
Level 4
Level 4
Cross posting... shame, shame.
