Invert Data on 3800 router!
pmpesha
Greetings,
Why is the invert data command not supported on 3800, Does the router support this function by default? Please assist. Thank you.
jackyoung
Level 6
Level 6
According to below link and some info. in CCO.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_command_reference_chapter09186a00800874b0.html#wp1017649
It supports 7xxx, 12xxx & Cat6500 only. Can't support 3800 model.
According to the doc., the invert data can be enabled at the CSU/DSU, you can try to check w/ the PTT for this option other than set it in the router.
Hope this helps.
thanks for the info.
