Help: IPv6 Route Summarization
jpl861
Level 4
Level 4
Hi Guys,
Can someone explain to me how to summarize an IPv6 network. Because with the book I am reading, I can't understand how the author came up with this.
IPv6 Networks:
2001:DB8:0:10::/64
2001:DB8:0:11::/64
2001:DB8:0:12::/64
2001:DB8:0:13::/64
IPv6 Summary:
2001:DB8:0:10::/62
Does it still have to deal with bits for summarization?
John
Edison Ortiz
Let's break it down:
0x10 = 0000000000010000
0x11 = 0000000000010001
0x12 = 0000000000010010
0x13 = 0000000000010011
The common bits are the first 14 bits, correct ?
Every colon you have 16 bits and the summarized portion is located in after the third colon, correct ?
So you have 16 x 3 = 48
Then you add 14 bits from the fourth column (the common bits we discussed above) and you have 62.
HTH,
Edison Ortiz
HTH,
Thank you very much Edison. This solved my problem. I forgot that this is hexadecimal and not decimal. I'm still trying to absorb all the IPv6 fundamentals right now. Thank you so much.=)
