QoS not working
mtechnology
I have a 3750 stack of 2 switches and have configured the following QoS configurations on them.
There are avaya phones connected to these switches. The QoS doesn't seem to be working.. am i missing something
i do not see any ACL matches nor do see packets matching the policy map
Here is my configuration
mls qos
mls qos map cos-dscp 0 8 18 26 34 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 1 4
mls qos srr-queue output cos-map queue 3 threshold 3 2
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 1 1
mls qos srr-queue output dscp-map queue 1 threshold 3 46 40
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 2 threshold 2 24 26 28 30
mls qos srr-queue output dscp-map queue 2 threshold 1 32 34 36 38
mls qos srr-queue output dscp-map queue 3 threshold 3 16 18 20 22
mls qos srr-queue output dscp-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8 10
mls qos queue-set output 1 threshold 2 75 85 50 400
mls qos queue-set output 1 threshold 4 15 100 50 400
ip access-list extended VOICE
permit udp 172.16.220.0 0.0.0.127 any range 16384 32767
class-map match-all VOICE
match access-group name VOICE
policy-map VOICE-ACCESS
class VOICE
set ip dscp ef
interface range FastEthernet1/0/1 - 48
switchport access vlan 2
switchport trunk native vlan 2
switchport mode trunk
switchport voice vlan 20
service-policy input VOICE-ACCESS
thnaks in advance
bvsnarayana03
Level 5
Level 5
add this cmd to all the interfaces to which voip phones are connected:
"mls qos-trust dscp"
Chk if this helps, as it servd my purpose in similar case.
edgar.reinke
You have to find another way to check your configuration. On most switches the qos related ACL and the show policy-map interface command do not show any counters. Seems to be the price we have to pay for hardware based qos ...
KR,
Edgar
edgar.reinke
... but you can use the command and check for the values.
Do not follow the advise to configure command on the interface, because this will remove your service-plicy from the interface: You can trust, or set the dscp bits ... but not both.
Edgar
