Help me in BGP concepts
Amr Ali
Dear All,
I hope every one in a good condition , kindly i need an assistance as i am a beginner in CCNP routing so i need to understand many of things , i have uploaded a topology made by GNS3 which had done by me but i need to understand why R1 can't ping R5
Thanks for Help
3 Accepted Solutions
Hello
Try this:
R4
router ospf 1
network 10.1.45.1 0.0.0.0 area 0
redistribute bgp 5500 subnets
router bgp 5500
redistribute ospf 1 match internal external 1 external 2
neighbor 1.1.1.1 next hop-self
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Amr,
I loaded up your gns topology this morning, and you actually had a couple of things going on so I'll break them down. Along with what I stated last night, you should have added the network statement to R5 and on R4 the next-hop-self statement for R1.
Paul stated correctly that you needed to redistribute ospf into bgp. After redistributing ospf on R4, R5 knows how to get to R1 via R4's loopback, and it does a recursive lookup to get to 4.4.4.4 it will go to R2 or R3 which is where the traffic is dropped. Being that R4 has a connected route, it doesn't redistribute that route into bgp, so advertising the network into ospf via the network command or redistribute connected would resolve the issue. You can do a one way redistribution from ospf into bgp and it would still work fine.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
"i need to understand why i must provide BGP  with another routing  protocol like OSPF or EIGRP to complete routing"
Well, you don't. You can have just BGP in your environment and it will work fine, or you can run an IGP like ospf or eigrp all over the place and it will work fine as well. The primary difference is that BGP was designed to be able to hold hundreds of thousands of routes if you have enough memory to hold a full routing table. An igp on the other hand was designed to route internal subnets, so you wouldn't, in general, have hundreds of thousands of routes. An IGP can't handle the same amount of routes that bgp can.
"i need to know  when i must use cmd # Network at BGP & cmd #  Neighbour"
Network command under bgp allows for you to advertise the specific network. The network needs to be in the routing table in order to advertise though, and bgp needs an exact match. 10.10.10.10/32 is not the same as 10.10.10.0/24 under bgp. BGP would need "network 10.10.10.10 mask 255.255.255.255" in order to advertise the 10.10.10.10/32 address. The neighbor command tells bgp who to connect to to share those addresses with by peering up with them. BGP works on a unicast address and has a direct connection to another peer. By default bgp has a ttl of 1, which means that it has to be a directly connected peer. You can disable that check though if you're peering with someone on the other side of a next hop or a loopback address.
"why we have used cmd #  Network at R5 only and didn't use it at any other router "
R5 was running BGP, but wasn't advertising anything. Technically, I'd have to lab this up again when I get back home to test it, but you probably didn't need it after all and here's why. R5 was connected directly to R4 10.1.45.0, so R4 knew how to get to R5 and vice versa. The problem is that R1 thought to get to 10.1.45.0, it needed to go to 4.4.4.4. 4.4.4.4 went to R2 or R3, but R2 or R3 didn't know about 10.1.45.0 and dropped the packet. So, in reality, you could have kept your peering with R1 --> R4 --> R5 and only advertise the 10.1.45.0 in ospf on R4. You would still have to redistribute into BGP so R5 would know how to get to your other subnets unless you wanted to advertise a default route to R5 from R4.
HTH,
John
19 Replies 19
John Blakley
It would be easier if you posted your configs and a screenshot of your topology. Can you post those?
HTH,
John
Dear John ,
Here your Request
R5
#sh
R5#show run
R5#show running-config
Building configuration...
Current configuration : 1180 bytes
version 12.4
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
ip tcp synwait-time 5
no ip domain lookup
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 10.1.45.2 255.255.255.252
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router bgp 6500
no synchronization
bgp log-neighbor-changes
neighbor 10.1.45.1 remote-as 5500
no auto-summary
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R4
version 12.4
hostname R4
boot-start-marker
boot-end-marker
enable password amr
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback4
ip address 4.4.4.4 255.255.255.255
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 10.1.45.1 255.255.255.252
interface Serial1/1
ip address 10.1.24.2 255.255.255.252
interface Serial1/2
ip address 10.1.34.2 255.255.255.252
interface Serial1/3
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 4.4.4.4 0.0.0.0 area 0
network 10.1.24.0 0.0.0.3 area 0
network 10.1.34.0 0.0.0.3 area 0
router bgp 5500
no synchronization
neighbor 1.1.1.1 remote-as 5500
neighbor 1.1.1.1 update-source Loopback4
neighbor 10.1.45.2 remote-as 6500
no auto-summary
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
password amr
login
end
R3
version 12.4
hostname R3
boot-start-marker
boot-end-marker
enable password amr
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 10.1.13.2 255.255.255.252
interface Serial1/1
ip address 10.1.34.1 255.255.255.252
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 1
network 10.1.13.0 0.0.0.3 area 0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
password amr
login
end
R2
version 12.4
hostname R2
boot-start-marker
boot-end-marker
enable password amr
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 10.1.24.1 255.255.255.252
interface Serial1/1
ip address 10.1.12.2 255.255.255.252
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 1
network 10.1.12.0 0.0.0.3 area 0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
password amr
login
end
R1
version 12.4
hostname R1
boot-start-marker
boot-end-marker
enable password amr
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback1
ip address 1.1.1.1 255.255.255.255
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 10.1.12.1 255.255.255.252
interface Serial1/1
ip address 10.1.13.1 255.255.255.252
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 1
network 1.1.1.1 0.0.0.0 area 0
router bgp 5500
no synchronization
neighbor 4.4.4.4 remote-as 5500
neighbor 4.4.4.4 update-source Loopback1
no auto-summary
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
password amr
login
end
Can you post "show ip bgp" from R5 and R1?
HTH,
John
Actually, on R5 you're not advertising any networks for R1 to get back to. You'll need to advertise the serial interface to R4:
R5:
router bgp 6500
network 10.1.45.0 mask 255.255.255.252
I see a logical peering from R1 - R4 with ibgp and from R4 - R5 with ebgp. For iBGP connections, the ibgp router doesn't modify the next hop. If R1 doesn't have a route to the advertising router on the other side of the ibgp neighbor, it won't be able to get to it. On R4, you would need to change your peering to R1 like:
R4:
router bgp 5500
neighbor 1.1.1.1 next-hop-self
Okay, it's late here, so I may have confused you even more...apologies if I did.
HTH,
John
Dear John ,
Sorry for inconvenience but i have tried your cmds
R5:
router bgp 6500
R4:
router bgp 5500
R1:
router bgp 5500
neighbor 4.4.4.4 next-hop-self
but still can't ping so what's the issue here
Amr Ali
hello all ,
Can any one help
Cheers
kindly post the sh ip bgp summ from R5 and R1
thanks,
Fady
Dear Fady,
@ R5
R5#show ip bgp summary
BGP router identifier 10.1.45.2, local AS number 6500
BGP table version is 1, main routing table version 1
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
10.1.45.1       4  5500       4       4        1    0    0 00:01:12        0
@R4
R4#show ip bgp su
R4#show ip bgp summary
BGP router identifier 4.4.4.4, local AS number 5500
1.1.1.1         4  5500       5       5        1    0    0 00:02:11        0
10.1.45.2       4  6500       5       5        1    0    0 00:02:06        0
R4#
@R1
R1#sh ip bg su
R1#sh ip bg summary
BGP router identifier 1.1.1.1, local AS number 5500
4.4.4.4         4  5500      11      11        1    0    0 00:08:45        0
R1#
the bgp neighbourship is running well , but no network advertised as i didn't use cmd  #network at all , i need someone can correct my configuration which i have posted to see where is the error
Best Regards
use redistribute ospf 1 under bgp 5500
Router bgp 5500
resdistibute ospf 1
Hello
Try this:
R4
router ospf 1
router bgp 5500
res
Paul
Thanks.
Kind Regards
Paul
Amr,
HTH,
John
Hello John
If router 5 advertised anything else other than it connect subnet into bgp then R1 would not able reach it as the opsf core routers would not know how to reach the prefixes, hence my suggested mutual  redistribution with  bgp in ospf also?
res
Paul
Thanks.
Kind Regards
Paul
John Blakley
Paul,
That would be correct, but the original post only requested to be able to ping R5 from R1. You're correct that if there were other networks involved on R5, redistribution would be necessary, but in this case the only thing that needs to be done is for R4 to advertise its connected network so R3 knows how to get to it. Right now, R1 is sending traffic destined to R5 via the loopback for R4 (4.4.4.4). R1 has to do a recursive lookup and send it to R2 or R3, but then R2 or R3 drop the traffic because they didn't know about 10.45.1.0/30. In this case, redistributing bgp wouldn't help because R4 sees that has a connected route and has a rib failure for bgp because it's connected route is better than what R5 is advertising. Because of the rib failure, R4 has to advertise the subnet that connects to R5, like you suggested originally or by redistributing connected routes. The problem with redistributing the connected route would be that now ospf would have a type-5 lsa that really doesn't need to be.
HTH,
John
Amr Ali
Dear Paul & John
I am very Thankful for your help & efforts , it's now working very well , but now i need to understand these cmds
# redistribute bgp 5500 subnets
# redistribute ospf 1 match internal external 1 external 2
also i need to know what is the meaning of " match internal external 1 external 2 " plus  i need to understand why i must provide BGP with another routing  protocol like OSPF or EIGRP to complete routing & i need to know  when i must use cmd # Network at BGP & cmd # Neighbour & the difference bet. them & why we have used cmd # Network at R5 only and didn't use it at any other router
Thanks for your time & Help
Regards - amr
