Help me interpret this prefix-list
hfakoor222
ip prefix-list RTBH-filter permit 100.68.0.0/16 ge 32
Does that mean any prefix that has 100.68.x.x    where the x.x  has to be filled out?
for example it includes   100.68.10.1   and not   100.68.10.0
and so does
ip prefix-list RTBH-filter permit 100.68.0.0/16 ge 24
mean  100.68.x.y   where it has to be 100.68.x   with y 0-255?
i.e  it includes both   100.68.10.0    and 100.68.10.1
am I right in my assumptions?
Thank you
SinghRaminder
So i created some LoopBacks on R2, some with /17 and some with /24 and then some with /32 subnet mask, like this :
int lo1
ip address 100.68.0.1 255.255.128.0
int lo2
ip address 100.68.128.1 255.255.128.0
int lo3
ip address 100.68.129.1 255.255.255.0
int lo4
ip address 100.68.130.1 255.255.255.0
int lo10
ip address 100.68.250.1 255.255.255.255
int lo11
ip address 100.68.251.1 255.255.255.255
int lo12
ip address 100.68.252.1 255.255.255.255
###PREFIX-LIST###
ip prefix-list RTBH-filter seq 5 permit 100.68.0.0/16 ge 32
###ROUTE-MAP###
R2#show run | s route-map
redistribute connected route-map RM-RTBH
route-map RM-RTBH permit 10
match ip address prefix-list RTBH-filter
####ROUTER BGP####
R2#show run | s router bgp
router bgp 20
bgp log-neighbor-changes
neighbor 192.168.1.1 remote-as 10
address-family ipv4
neighbor 192.168.1.1 activate
exit-address-family
I am redistributing all the connected routes but if you check the routes on other side, only /32 routes are learned
R1#show bgp ipv4 unicast
BGP table version is 6, local router ID is 192.168.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 100.68.250.1/32 192.168.1.2 0 0 20 ?
*> 100.68.251.1/32 192.168.1.2 0 0 20 ?
*> 100.68.252.1/32 192.168.1.2 0 0 20 ?
Rest of the routes are not learend
Raminder
PS: If this answered your question, please don't forget to rate and select as validated answer
10 Replies 10
The article was very helpful, I think I need more practice and so I will do a cisco created lab on prefix lists
this photo I make it as reference for me
NOW for your statement
/16 the prefix-list don't care about what you enter
32<- this value is wrong
 if we change the statement into
ip prefix-list RTBH-filter permit 100.68.0.0/0 ge 16
here the prefix-list will include all subnet form
100.68.0.0/16-------100.68.0.0/32
 This prefix list dont make sense to me as "ge" is "greater than" and how can you have a net mask greater than 32?
 Should be ge /16 or le  /32.
Ayye Ok, it is what was included in the lab
I think the prefix will only allow 32 prefixes on the 10.16.0.0/16. You do that if you want to deny any other prefix
See the example in the picture attached from the ENCORE book.
SinghRaminder
As others mentioned, ge 32 does not makes sense in this. But let's say it was given to you as ge /24 , then 100.68.0.0/16 will act as basé and any route with /24 or more was going to be matched and rest not.
For example 100.68.10.0/17 was not going to be matched but 100.68.10.0/25 was going to be matched with your statemenr
Raminder
Hello
This prefix-list states - Allow all 100.68.x.x routes/network that has a prefix-length that is greater or equal to /32
meaning any 100.68.x.x host routes
100.68.x.x/32
This prefix-list states -  Allow all 100.68.x.x routes/networks that has a prefix-length that is greater or equal to /24
100.68.x.x/24
100.68.x.x/25
100.68.x.x/26
etc..
100.68.x.x/32
Kind Regards
Paul
SinghRaminder
To explain what Paul mentioned... I will lab it up for you. Stay tuned
Raminder
SinghRaminder
int lo1
int lo2
int lo3
int lo4
int lo10
int lo11
int lo12
###PREFIX-LIST###
###ROUTE-MAP###
####ROUTER BGP####
router bgp 20
address-family ipv4
exit-address-family
Raminder
